In this article
http://www.larryjordan.biz/compressor-up-res/
mr Larry Jordan describes how to improve the video quality using the software Compressor 4 (or 3). This software is an Apple-software. Does anybody know if there is a similar option using PC-sofwares, for example Adobe Premiere Elements and Magix Movie Edit Pro MX. I have tried the "Super Resolution"-software (a Virtual Dub-plugin) but the result is zero (as far as I can notice) and using Super Resolution demands that you double, at least, the input video pixel size.
Results 1 to 12 of 12
I had a look and wasn't that impressed at the final results. At least he's honest enough to say it won't always work that well, but I think that's being generous.
There's just no way you can make 480p sd as good as 11080p (or even 720p IMO) hd. You can't put in information that isn't there. Your eyes may be able to tell what it should look like but software can't.
I certainly wouldn't consider it worth the encoding time required. -
As mr Jordan says: "SD video doesn’t contain enough pixels to fill an HD image. An NTSC SD DV image contains 345,600 pixels, while a 1080 HD image contains 2,073,600. Talk about scraping too little butter over too much bread".
BUT the Compressor 4-software does not work that way as far as I can see. It seems to work similar to the way the "Super Resolution" Virtual Dub-plugin works. -
No upscaler really restores the original detail. At best, they attempt to upscale while keeping sharp edges but not producing jaggies and buzzing edges when in motion. Super Resolution techniques use multiple frames to better analyze how the upscaled image should look. They work best when there is a tiny bit of motion between successive frames. Not so well with still shots or moderate to high motion shots.
Ifognition cherry picks their shots and vastly exaggerates the before and after images at their web site. They gratuitously show nearest neighbor upscales (the worst possible method) to their upscaling method. If you haven't seen it, you might find their detailed comparison of several different algorithms useful:
http://www.infognition.com/articles/video_resize_shootout.html -
I have tried the Infognition Super Resolution software using SD-vhs-4:3-files as input. My experience: useless
Try something like:
That's a 4x scaling that looks better than a single nnedi3_rpow(4). needi3 tends to shift the image up and left. The Flips help keep it centered. Of course, you want to remove blocking and DCT ringing artifacts and other noise before scaling.Code:nnedi3_rpow2(2) Sharpen(0.3) FlipVertical().FlipHorizontal() nnedi3_rpow2(2) Sharpen(0.3) FlipVertical().FlipHorizontal()
Maybe there is some misunderstanding -
Guys, that's what those articles , programs , scripts, mentioned in this thread are used for : Upscaling. ie Increasing the frame dimensions. Upscaling to HD of course won't be DVD complaint
You can still use SR techniques by multiples of 2 (2x, 4x, etc...), and then downscale to your final resolution. If input = output resolution, then of course there will be no benefit -
super resolution in vlc , really doesnt interest me
i've seen those 'results' reports
the quoted nee3 doublr flip double upscaling interest me
in converting some old avi rips processed for vcd and mobile
to bring up the res to DVD size, IF the results is better than a straight lacross resize
that is my question , how does it compare , and will it work in avisynth -
You can use "cshift" parameter of nnedi3_rpow to prevent shifting
BTW many the "PSNR" values that Infognition present are misleading because of the shifting that isn't corrected for in their testing. So of course upscaled algorithms that shift will create lower PNSR values...Ifognition cherry picks their shots and vastly exaggerates the before and after images at their web site. They gratuitously show nearest neighbor upscales (the worst possible method) to their upscaling method. If you haven't seen it, you might find their detailed comparison of several different algorithms useful: -
How Can I Improve my video quality
By legend10 in forum Newbie / General discussionsReplies: 36Last Post: 23rd Feb 2012, 14:01 -
How would you improve the quality of this video?
By choobies in forum Newbie / General discussionsReplies: 0Last Post: 28th Nov 2011, 12:24 -
Improve video quality [HELP]
By v1rto in forum Newbie / General discussionsReplies: 8Last Post: 13th Jul 2011, 08:46 -
how to improve video quality?
By George2 in forum ProgrammingReplies: 1Last Post: 19th May 2009, 02:07 -
Low quality video on high resolution screen, improve video quality?
By Nitrius in forum Software PlayingReplies: 4Last Post: 29th Dec 2008, 13:38
