i have a footage is HD XDCAM 25p, but when i put into FCP version 7.0.3 will be jitter problem. Always return back from my client, and can't to solve this problem. In Mac Pro easy setup only had 25i or 50i interlaced. When facing the pan shot must had jitter. i had try to put it flicker or de-interlaced or convert file to 25i. All can't to solve it.
i really needed your all kindly help.
thanks~
I'm not familiar with that camera's output, but if it's interlaced, the jitter during panning you refer to may be caused by field order being incorrectly handled in your software. Look for an option in FCP where you can specify something like Top Field First (TFF) vs. Bottom Field First (BFF).
Cheers,
Francois
interlaced and progressive in same video. how to make only progressive.
By OmniShadow in forum Newbie / General discussionsReplies: 32Last Post: 18th Sep 2012, 23:44 -
Progressive Vs Interlaced?
By shagratt71 in forum Video ConversionReplies: 4Last Post: 26th Dec 2011, 09:22 -
Interlaced or progressive
By rank in forum Newbie / General discussionsReplies: 4Last Post: 3rd Jul 2010, 16:41 -
Progressive vs Interlaced Regarding Motion
By Brent212 in forum Newbie / General discussionsReplies: 6Last Post: 15th Jul 2009, 19:26 -
Does de-interlaced video = progressive?
By yoda313 in forum RestorationReplies: 13Last Post: 18th Aug 2008, 19:51
