  1. is it possible to disble the deblocking in x264 and use Deblock_QED instead of it?
  2. x264 internal Deblocking is not a simple deblock like Deblock_QED, it's a inloop deblocker and it's definitely no good idea to disable it.
    It's not ment do remove blocking from the source, but to help compression.
    So:
    1. yes one can disable the in loop deblocker in x264
    2. it's a bad idea to do so
    3. So replacing the inloop deblocker with Deblock_QED does not make any sense. Since the two have different goals and work differently.
    -> No, it's not possible to replace x264s deblocker through Deblock_QED.
    If you need to deblock your source, use Deblock_QED, Unblock() or any other deblocker before feeding the then filtered video to x264.
  3. So is it safe to use both of them?
