    Apr 2013
    The Netherlands, Driebergen
    I realised a backup/copy a lot of TV movie from a HD-DVD-Recorder to my PC-HDD (by removing the internal HD of that recorder and connect it with help of IDE-USB adapter and with Linux, Ubuntu 12.04 on the PC as O.S.).
    The 90 movies I can now play on my pc with help of VLC, a splendid media player.
    However, I will edit some of the movies, e.g. split and delete clips, etc.
    I still have Adobe premiere 4 (on Windows-XP+SP3) and decide to execute the edit action with this video editor. But that was (till now) without success, resulting in a error message:
    "Error FILE FORMAT NOT SUPPORTED , one of the necessary components may not be installed”.
    Which component is mentioned? Perhaps it has to do with a missing CODEC?
    Which one is needed for MPEG_4?
    Mar 2011
    Nova Scotia, Canada
    Mpeg4 is generally pretty standard. Open one of them in mediainfo and post results of text modce.
    Apr 2013
    P { margin-bottom: 0.08in; } The <Cmd: MediaInfo> applied to the movie /TITLE.VOB/Content01 (copied from a HD-DVD recorder to my PC-HD) found an index file “Content01.idx” in the same folder.
    This index file was the result from using the Video Editor “Avidemux” yesterday.
    As result of its message: “This looks like mpeg. Do you want to index it” <yes>.
    For reason I did not understand the content of this idx file, I returned to <Avidemux> and clicked to <file> and <properties> with a more understandable result, see my screen shot of it.
    There is written: Video Codec 4CC: MPEG and Audio Codec: AC3.
    Hopefully this makes it possible to edit this movies, see above, my question to the forum.
    I should appreciate if you, Sir Rob Hoser, will give me details and advice how to solve it.
    Perhaps, you may also give me a location on INTERNET for a user manual of Avidemux?
Name:	Screenshot from 2013-04-07 18:13:28.png
