    Apr 2013
    Australia
    "An error occured while writing this file the reason for this error could not be determined"
    I get this error on DVD architect and I do not know what to do.
    I rendered everything on vegas.
    I have tried uninstalling and re installing and changing drives and temp folder
    Feb 2004
    Australia
    Welcome mrrhys
    Which version of dvd architect ?
    Likely prep to dvd ... which isn't going to happen
    Take a look at the menu screen that pops up when you select "Make DVD".
    At the bottom, it says
    Prepare DVD = creates all the files needed for the dvd to temp folder
    Burning = burns them to a DVD."
    Use prepare and make sure you have adequate free space.
    Other bugs which can produce the same error are
    1: More than 4 chapter markers
    2: More than 9 titles
    3: Menu content if encoded exceeds the 1 gb limit
    4: Make sure project is 500mb short of filling intended media
    Latest version tends to have most bugs sorted ... check for version update.
    Apr 2013
    Australia
    I have 6
    I have about 200 gb of space
    I wanted to use the program for the menu for a video on my comp not for a dvd, so it is way over the limit but I did not think that would matter
    Apr 2013
    Australia
    It would not work for BluRay Either
