Trying to use ffmpeg to do a conversion (remux) over to mp4 container:
ffmpeg -i blah.avi -vcodec copy blah.mp4
This works to play the file everywhere except in a flash player I'm trying to embed on my site. If I re-encode the file then it works in the flash player:
ffmpeg -i blah.avi blah.mp4
This is fine but the processing resources and time is massive compared to just remuxing. I'm using ffmpeg 1.2 and the remux looks like this:
Anything I can do to get remux to work?Code:./ffmpeg -i myfile.avi -vcodec copy myfile.mp4 ffmpeg version N-51169-gcedf276 Copyright (c) 2000-2013 the FFmpeg developers built on Mar 21 2013 05:12:00 with gcc 4.6 (Debian 4.6.3-1) configuration: --prefix=/root/ffmpeg-static/32bit --arch=x86_32 --extra-cflags='-m32 -I/root/ffmpeg-static/32bit/include -static' --extra-ldflags='-m32 -L/root/ffmpeg-static/32bit/lib -static' --extra-libs='-lxml2 -lexpat -lfreetype' --enable-static --disable-shared --disable-ffserver --disable-doc --enable-bzlib --enable-zlib --enable-postproc --enable-runtime-cpudetect --enable-libx264 --enable-gpl --enable-libtheora --enable-libvorbis --enable-libmp3lame --enable-gray --enable-libass --enable-libfreetype --enable-libopenjpeg --enable-libspeex --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-version3 --enable-libvpx libavutil 52. 22.100 / 52. 22.100 libavcodec 55. 1.100 / 55. 1.100 libavformat 55. 0.100 / 55. 0.100 libavdevice 55. 0.100 / 55. 0.100 libavfilter 3. 48.100 / 3. 48.100 libswscale 2. 2.100 / 2. 2.100 libswresample 0. 17.102 / 0. 17.102 libpostproc 52. 2.100 / 52. 2.100 [avi @ 0x9fff660] non-interleaved AVI Guessed Channel Layout for Input Stream #0.1 : mono Input #0, avi, from 'myfile.avi': Metadata: encoder : Lavf52.64.2 Duration: 00:00:10.40, start: 0.000000, bitrate: 409 kb/s Stream #0:0: Video: h264 (Baseline) (H264 / 0x34363248), yuvj420p, 640x480, 10 fps, 10 tbr, 10 tbn, 30 tbc Stream #0:1: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 8000 Hz, mono, s16, 128 kb/s Output #0, mp4, to 'myfile.mp4': Metadata: encoder : Lavf55.0.100 Stream #0:0: Video: h264 ([33][0][0][0] / 0x0021), yuvj420p, 640x480, q=2-31, 10 fps, 10240 tbn, 10 tbc Stream #0:1: Audio: aac ([64][0][0][0] / 0x0040), 8000 Hz, mono, s16, 128 kb/s Stream mapping: Stream #0:0 -> #0:0 (copy) Stream #0:1 -> #0:1 (pcm_s16le -> libvo_aacenc) Press [q] to stop, [?] for help [mp4 @ 0xa006ea0] pts has no value Last message repeated 100 times frame= 101 fps=0.0 q=-1.0 Lsize= 350kB time=00:00:11.06 bitrate= 259.3kbits/s video:332kB audio:15kB subtitle:0 global headers:0kB muxing overhead 0.926809%
				Results 1 to 1 of 1
  need to put content of FLV container into MP4 containerBy arraboy in forum Newbie / General discussionsReplies: 3Last Post: 29th Jun 2012, 20:52
  Want to convert MJPEG muxed in AVI container to MP4 for Youtube.By gOdiSOnyOuRsIDe in forum Video ConversionReplies: 2Last Post: 20th Jun 2012, 19:54
  H264+AC3 (MKV container) to H264+MP3 (MKV container)By diebri in forum Video ConversionReplies: 3Last Post: 19th Oct 2011, 07:19
  Mux h264.mp4 into avi container?By ayim in forum Video ConversionReplies: 4Last Post: 11th Feb 2010, 07:18
  What do I do with a raw .h264 file extracted from an .mp4 container?By godfist314 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2008, 13:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
