I have a sony dav s300 dvd player. i used convertxtodvd to convert 2 movies to dvd format at then burnt it on a moserbaer dvd+rw 4.7gb at 1x speed. however when i insert the disc it says "no disc". what should i do? is it a problem with disc type or the burning software? pls help!
Results 1 to 9 of 9
Yes, it's most likely a problem with the disc.
It wont play CD-R/RW, DVD-R/RW, MP3s and multi-regional DVDs (and probably DVD+RW by the look of it).
Try it with a DVD+R. If that doesn't work...give up. It's very choosey about what it will play. -
I would guess that the DVD+RW is the problem. From what I could find out about it, your player, dates from 2000-2001. That being the case, it is likely that your player is unable to read DVD+RW and possibly other burned DVD media as well. DVD+RW and other burned DVD media were were not common back then.
An old girlfriend of mine had one of the very early Sony DVD players that would not accept ANY homemade disc....not even CD-R.
Some older DVD players may only support DVD-R or DVD+R but not both, and/or mightn't read re-writable discs well, if at all.
You might be able to change the booktype when burning for better compatibility. http://en.wikipedia.org/wiki/Book_type
What's the rated burning speed of the discs? Burning at 1x probably won't increase the quality, and could in fact reduce it. See the "Myth of burning slower" section on this page: http://www.digitalfaq.com/guides/media/dvd-media-concepts.htm -
According to the second review at http://www.amazon.co.uk/Sony-DAV-S300-Home-Cinema-System/dp/B00005Q3DO the unit supports DVD-R/-RW only and won't work with DVD+R/+RW recordings. I have an old Toshiba player with same DVD-R/-RW specifications, and it will play DVD-R and DVD+R media that are bitset to DVD_ROM recordings but won't play DVD+R recordings. This Sony should have the same playback ability.
Re-read those user reviews with your reading glasses on this time.
The second review at the link you gave says it does not play DVD-RW or DVD-R media:
I bought this Sony-system a couple of years ago and have used it with pleasure. It is great to have a tuner, CD, and DVD-system in one. The sound on the system is great, especially with good DVD-films. However, the system now starts to show its age - it does not play CD-R/RW, DVD-R/RW, MP3s and multi-regional DVDs. I would love to upgrade just the player and keep the speakers. As long as you know the restriction of this system you will be satisfied. -
AH, the curse of the combo system. We have a used Panasonic surround sound system which includes a DVD player - which does not upconvert, doesn't understand PAL, doesn't... On the other hand, the $12 price was quite reasonable.
You're exactly right. I simply misread it initially. Sorry about that. However, that brings to mind another problem I had with my old Toshiba player. That Toshiba would also not play any recordings from LiteOn LVW-5005 recorder regardless of media type except DVD+R bitset to DVD-ROM which might work for the Sony. Another possibility is moserbaer media is low quality media from what I've read. I'd try bitsetting to DVD-ROM first and try better media if bitsetting doesn't fix the problem.
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 21:15 -
Windows Media Player dont play mpeg2
By mogoyon in forum Software PlayingReplies: 4Last Post: 14th Jan 2009, 13:31 -
Does Philips DVP 5990 play home burnt double layer DVD videos?
By indyram in forum DVD & Blu-ray PlayersReplies: 13Last Post: 28th Dec 2008, 10:06 -
ARE THERE DVD / BLU-RAY Players that PLAY 720P DIVX FILES FROM BURNT DVD'S
By likesmeso in forum DVD & Blu-ray PlayersReplies: 3Last Post: 27th Nov 2008, 08:10 -
Would this DVD player play AVI files burnt onto a blank DVD/CD?
By jane2 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 20th Apr 2008, 19:38
