Hello,
i want to access to this window:
without VirtualDub.
I discovered the settings of the color change (change brightness / contras, etc.) in "Debut Video Capture Software" are fake.
It does not make a real change. It does not change the hardware settings ..
But I noticed that if I open the "Debut Video Capture Software" and the VirtualDub While Debut displays the image from the device, so if I get this window via VirtualDub and change the color settings, I see the change in Debut directly.
So all I need is an easy way to get to this window ..
I have problems with recording in VirtualDub.
(My device is eastcap)
I hope you understand me.
Thanks for helpers!
