  1. Hello to all! I have a 352x480 mpeg2 video which is 2hrs long but I want to clean it up because the quality is not good. What are the steps to fix this and is is best to resize it. I'm a newbie with this so please help me
    http://imageshack.us/photo/my-images/96/nve00006b.png/
    http://imageshack.us/photo/my-images/600/nve00005.png/
    http://imageshack.us/photo/my-images/841/nve00004.png/
    http://imageshack.us/photo/my-images/828/n.../nve00003o.png/
    http://imageshack.us/photo/my-images/52/nve00002r.png/
    Here is video info:
    Complete name : C:\Users\WJL\Documents\NeroVision\ImportedVideo\4-2-2013 70445 PM.0001\0001.mpg
    Format : MPEG-PS
    File size : 1.99 GiB
    Duration : 2h 0mn
    Overall bit rate : 2 368 Kbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Default
    Format settings, GOP : M=3, N=15
    Duration : 2h 0mn
    Bit rate mode : Variable
    Bit rate : 2 064 Kbps
    Nominal bit rate : 3 758 Kbps
    Width : 352 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 0.408
    Stream size : 1.73 GiB (87%)
    Audio
    ID : 189 (0xBD)-128 (0x80)
    Format : AC-3
    Format/Info : Audio Coding 3
    Muxing mode : DVD-Video
    Duration : 2h 0mn
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Delay relative to video : -67ms
    Stream size : 220 MiB (11%)
    Text
    ID : 224 (0xE0)-DVD-2
    Format : EIA-608
    Muxing mode, more info : Muxed in Video #1
    Stream size : 0.00 Byte (0%)
    I'm a newbie at this and i don't know where to start so I need help. I know this video can get better but I just need a step by step guide.
  2. Member DB83's Avatar
    Jul 2007
    For me it is quite impossible to guage the quality of a video from a few stills.
    You may wish to upload a small, typical sample.
    However, you have a low bitrate video and with all the 'cleaning up' you will still have a low bitrate video at the end of it.
    You will gain nothing by resizing it since it is already comprimised by the bitrate.
  3. Banned
    New York, US
    There is no version of VirtualDub that can help with this video. If anything, you'd have to work in Avisynth -- even then, weeks of work would get nowhere. Whoever "created" these vids made every mistake in the book, and then some.
