When I convert vob's to mpg, the volume of the audio is reduced on the mpg files. Is there any way to fix this in the VOB2MPGPRO program? I've tried checking the box, "Force AC3 Audio," in the settings, but that had no effect. I can boost the audio volume using my video editor, but that's a lot of trouble. I'd rather have the VOB2MPGPRO software maintain the original volume when it converts the vob's to mpg. Is this a bug, or is there a fix for this?
Thank you for taking the time to respond to my question. I found a free DVD to MPG program called WinX Free that converts my DVD to MPG files without any loss of volume. So I will just use that program instead of VOB2MPGPRO. Thanks for such a quick response.
100's of short titles with VOB2MPGPRO
By jossie in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 11th Aug 2011, 19:06 -
Hi8 -> DV -> Final Cut Pro = Low, low audio levels in captured video
By xmiller in forum Capturing and VCRReplies: 12Last Post: 14th Dec 2010, 16:59 -
Vob2MpgPro: loss of audio on seek forward
By aurgathor in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 17th Oct 2010, 21:28 -
How to get VOB2MPGPRO after buying it.
By asilveir in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 30th Jan 2010, 02:10 -
Joining mpg files from VOB2MPGPRO
By Mudmover in forum SVCD2DVD & VOB2MPGReplies: 14Last Post: 2nd Jun 2009, 07:06
