I know this is obviously a 'video help' forum, but I though it would be okay if I asked this question here...
Anyway, I often encode 1080i videos which have AC3 as the original audio codec, and I don't like to lose any audio quality when encoding, and I've read that AC3 passthru is completely lossless and will be exactly the same as the source, but I've also read that AC3 passthru is very good, but not exactly lossless.
Can someone please tell me if it is actually completely lossless or not?
Thanks in advance
				Results 1 to 9 of 9
	By definition passthrough means just that, pass it through, don't touch it.
 Don't know what software you're using, but the ones I use treat it that way.
	http://lifehacker.com/5559007/the-hassle+free-guide-to-ripping-your-blu+ray-collection
 Scroll down to where it says "Step Three: Set Your Quality Settings and Encode" and you will see where he talks about audio encoding.
	If that's the part you're worried about, don't be.It will likely be some form of either AC3 or DTS—there are a few different versions of each, but for each I recommend choosing the Passthru option for your Audio codec (AC3 Passthru or DTS Passthru). It isn't lossless, but it's pretty darn good and is by far the simpler option (lossless audio would require more software, more time, and more space, so we won't go into it in this how-to).
 The passthrough process is lossless, as in, what's on the disc is copied to your finale file without alteration. But regular ac3 or DTS core found on blurays do not use lossless compression, as say flac does.Last edited by Island_Dweller; 4th Apr 2013 at 10:08.
  Selecting passthru audio in MPC HC rather than the prologicBy skinney6 in forum AudioReplies: 2Last Post: 26th Jan 2012, 12:37
  Why are there 2 completely different 8mm formats??By impmon2 in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2011, 01:03
  completely new to avisynth...please helpBy unclescoob in forum Newbie / General discussionsReplies: 130Last Post: 12th Mar 2011, 22:49
  can't figure out passthru with JVC GR-DVL820UBy MajorMalfunkshun in forum Capturing and VCRReplies: 1Last Post: 3rd Jul 2009, 01:50
  and now for Something Completely Different...By ahhaa in forum Off topicReplies: 0Last Post: 28th Apr 2008, 10:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
