Results 1 to 1 of 1
  1. Hello. I'm a newbie so hopefully I'm in the right section to ask a question.
    I use a videoscribe author who creates videoscribes for me in two formats: MOV and LOSSLESS FLV. I can upload either the MOV or LOSSLESS FLV to youtube. The LOSSLESS FLV is ten times better quality on youtube.
    My question is this. Is there a way to edit LOSSLESS FLV and than render it in the same quality? My gut says that someone will recommend I convert the lossless FLV to a different format for editing. That's ok, if it all can be done so the final product is as good as the LOSSLESS FLV.
    So the steps I'm working with are:
    1. Creator exports and sends me the lossless FLV
    2. I want to edit the lossless flv
    3. Can I edit the lossless FLV directly
    Or do I
    Convert lossless FLV to a editable format and when done editing, I can save it in a lossless format with the same quality as the original lossless flv.
    Hmmm, not sure I explained the above well, but hopefully someone here can follow this newbies logic.
