removed answer since there's already a thread about it:
https://forum.videohelp.com/threads/354983-How-to-remove-cloud-picture-noise-that-McTem...19#post2231619Last edited by Selur; 3rd Apr 2013 at 14:34.
That thread is about a different video from a different season which has nothing to do with what I'm talking about in this thread.
True, that "other" video is different and doesn't have this problem. You might notice that the black stain is always on darker colors, doesn't seem to affect brighter ones. Part of that could be crushed colors (which are also in other areas of your sample), but either the tape or the player seems to have that problem -- I say that because the other borders have crushed darks, but no discoloring. Even if you could "remove" it (which you can't), there's no video data to fill in for it. All you'd have is blank video there.
How to remove cloud picture noise that McTemporalDenoise can't remove?
By VideoFanatic in forum RestorationReplies: 9Last Post: 3rd Apr 2013, 18:18 -
How to remove or smooth away tape header noise with Avisynth?
By VideoFanatic in forum RestorationReplies: 3Last Post: 20th Oct 2012, 22:18 -
Green stripe on left side of captured video screen. How to remove?
By videomatrix in forum Capturing and VCRReplies: 1Last Post: 17th Sep 2012, 22:17 -
Putting a black frame on left side only?
By gonzo90017 in forum EditingReplies: 5Last Post: 24th Dec 2008, 14:28 -
How to remove black side panels from a 4:3 picture recorded as 16:9
By topcat55 in forum Video ConversionReplies: 3Last Post: 14th Oct 2008, 01:56
