I have transfered VHS tapes to DVD's useing a Toshiba DVR670KU recorder. The DVD willplay on the TV but will not play on the computer. The computer will not evensee that a DVD has been inserted into the dvd drive.
The computer will play movie DVD's and movies that Idownloaded from my camera and camcorder to the computer and put them on a dvduseing Roxie. Can you help me.
Thank you for your help.
hghhdd@frontier.com
Hech54 - Thank you for your reply.
I forgot to put in the post " have the settings on the dvd recorder set to Finalizing and Compatible"
and it still did not work.
I havetransfered VHS tapes to DVD's useing aToshiba DVR670KU recorder. The DVD will play on the TV but will not play on thecomputer. The computer will not even see that a DVD has been inserted into thedvd drive.
I have thesettings on the dvd recorder set toFinalizing and Compatible and I thought that would make
it work onthe computer , but it did not.
The computerwill play movie DVD's and movies that I downloaded from my camera and camcorderto the computer and put them on a dvd useingRoxie. Can you help me.
Thank youfor your help.
Don Heeter
Richmond, IN
hghhdd@frontier.com
Toshiba DVD recorders are infamous for inexperienced users using them in modes that cause problems elsewhere. I am guessing that you have a VR mode issue, but someone else will have to help you with that.
You mentioned Roxio, although you misspelled it. If you are actually using an Apple computer, we definitely need to know that. I know that Roxio products run on Windows too, but they are fairly common on Apple. Knowing that you really have an Apple computer may be critical to solving your problem. -
On every Toshiba DVD recorder I've used (4 over the years), the default recording mode in the setup menu is called "Main". I don't know about the model mentioned. I once used the alternate VR mode out of curiosity, but had trouble playing it on other machines. Had to use TMPGenc Editor (which can read VR recordings) to import to the PC as plain MPEG, made some edits, then re-authored to standard DVD.
Jman98 - Thank you for your reply.
I am sorry for misspelling Roxio.
VHS to DVD w/o going through computer or if computer Roxio VHS -DVD?
By xxnonamexx in forum Capturing and VCRReplies: 5Last Post: 12th May 2010, 20:19 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 22:16 -
VHS to DVD to computer for editing
By JoeCB in forum Capturing and VCRReplies: 2Last Post: 10th Mar 2010, 16:52 -
Compare VHS to computer vs cheap HD to computer ending in youtube post
By gittarpikk in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 12:06 -
VHS to DVD recorder wont play on computer!
By topgun68 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 3rd Nov 2008, 14:56
