Yesterday i downloaded Video To Video Converter for editing/cutting MKv Files... i want to Cut some video segments from Mkv File... so in tools option of Converter i choose Cut commercial n added movie then i select that segment which i wanted to remove then clicked on OK...it asked me to select the output..i chose Direct Stream Copy(as i didn't want it to reencode the movie)...then i clicked on convert button..then nothing happened ..i tried it on other files also but still not wrking.. any help ?![]()
Cutting is very fast. Did you check the output folder?
I just tried it and it works fine, clicked on tools->split video, loaded a mkv, set start and stop, add segment, ok, choose direct stream copy, click convert, check the output folder.
iWisoft Free Video Converter producing blank (black) video?
By avideodummy in forum EditingReplies: 1Last Post: 8th Aug 2015, 12:55 -
ImTOO Video Converter Ultimate 6, audio-video synchronization error
By Mållgan in forum Video ConversionReplies: 1Last Post: 18th Jun 2013, 07:40 -
Converting 5.2gb .mkv video to DVD5 using Any Video Converter Professional
By supersi in forum Video ConversionReplies: 1Last Post: 10th Dec 2011, 03:06 -
bad quality of camstudio recorded avi video merged by avs video converter
By shimi in forum EditingReplies: 5Last Post: 25th Feb 2010, 16:33 -
any video converters have video joiner+converter to convert 640x360 resolut
By bournurplusher in forum Video ConversionReplies: 1Last Post: 27th May 2009, 08:52
