Results 1 to 11 of 11
    Dec 2006
    Bangladesh
    Greetings every on this forum...
    I have a question..
    say I have 5 original DVD saved in my HDD. IT has menus, extras, multiple audio, multiple subtitle.
    what I want, I want to create a single DVD from those 5 DVD.
    for example:
    start menu will list :
    movie 1
    movie 2
    movie x
    movie 5
    when click/select movie 1 it will play that DVD (not the movie directly, the original menu for that DVD) and when get back to root menu it will show the start menu (where all 5 DVD is listed)
    I hope I m clear..
    I tried easyDVD but it has many issue, it can only import movie, don't support dts, subtitles shows wrong and much issues
    so, any better solution/software suggestion please?
    will be waiting for reply
    thanks in advance
    best regards
    DVDremake Pro.
    Dec 2006
    Bangladesh
    hi, sir you again. thanks a lot
    you are so helpful..
    sir ,the issue is i tried dvdRemake pro but it only support up to 4 DVD not ore than that..
    i hope, i m clear.
    thanks again for your kind reply..
    best regards
    I see. I don't know any other methods that let you keep the original menus.
    Dec 2006
    Bangladesh
    thanks again for your reply
    what about "TMPGEnc Authoring Works" ?
    best regards
  6. Originally Posted by Shohag_ifas;2231390
    what about "[URL="https://www.videohelp.com/tools/tmpgenc-authoring-works"
    TMPGEnc Authoring Works[/URL]" ?
    best regards
    Nope. It's good software but not from THERE. That crap is not allowed here.
  7. You just need to run DVDremake twice. Combine two DVD to one. Combine this with the other three. (But 5 DVDs ?). It will not quite give you the menu you want with the "one click" solution. If you want the single menu with access to all 5 DVD you need to do some "manual" work in DVDRemake.
    Dec 2006
    Bangladesh
    thanks for your reply
    i didn't asked for on click solution..
    i can do some work for that..
    is there any way to extract all the dvd contents like menu (video), menu (audio), subtitle, main movide, movie audio? i know i can extract some of using pgcdemux but not sure whether it can extract menu (audio and video)?
    and also i used DVD Lab Pro, but it just not support .sup format subtitle..
    is it possible to make the dvd with dvd lab pro without subtitle and mux it later?
    i hope i m clear..
    please help me out..
    thanks in advance
    best regards
  9. Originally Posted by Shohag_ifas View Post
    ...but not sure whether it can extract menu (audio and video)?
    It can. Just tick 'Menus' in the 'PGC Selection' part.
    If I'm not mistaken it does support VobSubs (IDX/SUB) and SUP files can be converted to VobSubs instantly using SubtitleCreator.
    Yes.
    And sticking 5 full-length movies on 5 different DVDs into a single DVD - even a DVD9 - is a very dumb idea. Can't you afford the price of DVD blanks? They're cheap. This shows no respect at all for the films to ruin them in that way (after your country's home media companies have already done their best to ruin them).
    Dec 2006
    Bangladesh
    Yes.
    thanks a lot for your reply sir..
    but if i convert to sub from sup it's not looks good and even after use that sub file. in dvd lab pro, output dvd subtitle has some issue like not synchronize correct etc etc..
    and would you please guide me how to add/mux sup subtitle in a compiled dvd? please?
    thanks in advance..
    best regards
  11. Originally Posted by Shohag_ifas View Post
    ...but if i convert to sub from sup it's not looks good and even after use that sub file. in dvd lab pro, output dvd subtitle has some issue like not synchronize correct etc etc..
    I've never used DVDLab-Pro, but the timings of the VobSubs out of SubtitleCreator are the same as the original SUP file. Also, they're the same graphic subs so I'm not sure what you mean by 'not looks good'. If it's the colors you mean, that's easily fixed.
    As for adding SUP files after you've made the DVD, Baldrick has a guide for that. Ignore the part about making the subs, use his Method 2, and just learn the part about adding SUP files to an already made DVD:
    https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD
