Results 31 to 44 of 44
Thank you, I started adding the lines back and it worked - then I noticed that in the previous script I had Return(vid) in the last line.
This script works as I wanted.
Thanks again for your time and patience.
Code:a=FFVideoSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv", threads=1, seekmode=0).LanczosResize(640,264) b=FFVideoSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv", threads=1, seekmode=0).LanczosResize(640,264).reverse() vid=stackhorizontal(a, b) aud=FFAudioSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv") audiodub(vid,aud) info()
sambat, can you post the original avc video (trailer) that is giving you this problem ?
i'm curious to see if this happens on everyones machine with different codecs. it might be the way the video is being decoded. i had this problem several years ago and posted the same blocky issue but noone was able to resolve. i gave up and moved on. but i'd still like to check it out on my machine. thank you. -
whoops I totally glossed over that.... should have seen it right away
Huuuuuugee difference . I think a lot is going to depend on encoding settings and hardware. Some encoding settings will make this difference even larger . Faster / more cores/ hardware will be handicapped more by threads=1
vhelp - This is probably it
http://filessurf.com/File/aee0jl09o09pg -
nupe..link seems to take me to a divxplushd.exe file d/l. tx anyways.
found this link: http://www.divx.com/en/devices/solutions/high-definition/divx-plus-hd/video -
Another option is to use avsmeter , but with "veryfast" I suspect the difference or ratio will be similar on similar hardware/setup/video sample
http://forum.doom9.org/showthread.php?t=165528 -
huh ?? Did you push "download ?" . It's actually a re-direct
I just tried it right now... definitely works
Here is a direct link if you are having browser issues
http://divxtrailers.divx.com/GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv -
see link below, othewise, i already got it! .. tx 4 tryn
https://forum.videohelp.com/threads/349080-vhelp-Images-II?p=2200339#post2200339 -
confirmed. i d/l'ed latest/last version of dgavcdec109.zip and it ran through reverse() script, and it blocked in the same scene, and many others. however, when i feed the original .mkv file into scripplet below, symptom disapeared.
Code:x = "g:\GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv" LoadPlugin( "C:\PLUGINS\ffms2.dll" ) FFVideoSource(x, fpsden=1, fpsnum=24, width=720, height=304, seekmode=0) reverse()
seekmode=0
int seekmode = 1
Controls how seeking is done. Mostly useful for getting uncooperative files to work. Only has an effect on files opened with the libavformat demuxer; on other files the equivalent of mode 1 is always used. Valid modes are:
- -1: Linear access without rewind; i.e. will throw an error if each successive requested frame number isn't bigger than the last one. Only intended for opening images but might work on well with some obscure video format.
- 0: Linear access (i.e. if you request frame n without having requested all frames from 0 to n-1 in order first, all frames from 0 to n will have to be decoded before n can be delivered). The definition of slow, but should make some formats "usable".
- 1: Safe normal. Bases seeking decisions on the keyframe positions reported by libavformat.
- 2: Unsafe normal. Same as mode 1, but no error will be thrown if the exact seek destination has to be guessed.
- 3: Aggressive. Seeks in the forward direction even if no closer keyframe is known to exist. Only useful for testing and containers where libavformat doesn't report keyframes properly.
I tried with and without this - no difference in the processing time nor perceived quality;
for vhelp it works without threads=1
-> so simply using ffmpegvideosource solves the problem? -
I couldn't reproduce "blocky" results with ffvideosource eitherway with reverse on that sample , I think threads and/or seekmode are unecessary in this case . The error that he got earlier with FFMpegSource2 was from requestlinear
[QUOTE=Selur;2231641]
What are Video "Profile Formats" or "Levels"?
By HanDuet in forum Newbie / General discussionsReplies: 2Last Post: 15th Mar 2011, 23:41 -
Filtering the cult series "Invader ZIM" using Avisynth
By rm2kpro in forum Video ConversionReplies: 6Last Post: 24th Jul 2010, 21:10 -
DVD with menus, replacing "bad" video with "good" video
By chipsndukes in forum Authoring (DVD)Replies: 34Last Post: 4th Dec 2008, 17:45 -
Seeking avisynth function for "blend-a-field" idea
By vhelp in forum EditingReplies: 2Last Post: 21st Sep 2008, 20:52 -
Need some help with "dubbing"/"muxing" video with audio
By FSSSWE in forum Newbie / General discussionsReplies: 9Last Post: 21st Jun 2008, 18:49
