Results 1 to 30 of 44
    Dec 2005
    Canada
    Loading the script in VirtualDub, the video shows intermittent blockiness as it's stepped through.
    Turning off direct decoding in Preferences and allowing ffdshow to take over makes no difference.
    When the output is saved using the installed codecs - or an external codec - the same intermittent pattern shows.
    Neither DVD nor AVI clips behave this way.
    Feeding the script to MPC, same.
    In either scenario, when the feed is not reversed, there is no problem.
    Is it because it's a high resolution file or fast action or both;I tried resizing in the script but that made no difference.
    AVCSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD_Track00.dga").reverse()
    General
    Unique ID : 211134710336940616268497285024418626123 (0x9ED710EB85049A65BD467FE06A47FA4B)
    Complete name : E:\Office clip\_mkv\GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv
    Format : Matroska
    Format version : Version 1
    File size : 53.2 MiB
    Duration : 2mn 14s
    Overall bit rate : 3 327 Kbps
    Encoded date : UTC 2009-11-30 19:41:06
    Writing application : mkvmerge v2.6.0 ('Kelly watch the Stars') built on Mar 24 2009 15:23:17
    Writing library : libebml v0.7.7 + libmatroska v0.8.1
    TITLE : G.I. Joe - The Rise Of Cobra Trailer
    TITLE/Url : http://www.gijoemovie.com
    COPYRIGHT : 2009 by PARAMOUNT PICTURES. All rights reserved. G.I. JOE and related characters are trademarks of Hasbro and are used with permission. 2009 Hasbro. All Rights Reserved.
    COMMENT : Encoded in DivX Plus HD for the DivX Plus Web Player
    Video
    Format : AVC
    Format profile : High@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 12 frames
    Codec ID : V_MPEG4/ISO/AVC
    Duration : 2mn 14s
    Nominal bit rate : 3 200 Kbps
    Width : 1 280 pixels
    Height : 528 pixels
    Display aspect ratio : 2.40:1
    Frame rate : 23.976 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.197
    Title : Main title
    Writing library : x264 core 79 r1342 e8501ef
    Encoding settings : cabac=1 / ref=12 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.0:0.2 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-3 / threads=8 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=95 / keyint_min=25 / scenecut=40 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=3200 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=20000 / vbv_bufsize=25000 / ip_ratio=1.40 / aq=1:1.00
    Language : English
    Default : Yes
    Forced : No
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : A_AAC
    Duration : 2mn 14s
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Title : English 2ch Stereo
    Language : English
    Default : Yes
    Forced : No
    Text #1
    Format : UTF-8
    Codec ID : S_TEXT/UTF8
    Codec ID/Info : UTF-8 Plain Text
    Title : English
    Language : English
    Default : No
    Forced : No
    Text #2
    Format : UTF-8
    Title : French
    Language : French
    Default : No
    Forced : No
    Text #3
    Format : UTF-8
    Title : German
    Language : German
    Default : No
    Forced : No
    Text #4
    Format : UTF-8
    Title : Portuguese
    Language : Portuguese
    Default : No
    Forced : Yes
    Text #5
    Format : UTF-8
    Title : Spanish
    Language : Spanish
    Default : No
    Forced : No
  2. try:
    RequestLinear(rlim=50,clim=50) # comes with TIVTC
    reverse()
    if that doesn't help try ffmpegsource2 or LWLibavVideoSource instead of AVCSource.
  3. When frames are requested out of order many decoders will have problems with codecs that encode frames out of order. They get "confused" and start making gross errors like that. If you can't get the decoder working you'll have to resort to reading the file linearly and saving to a lossless intermediate. Then reverse that.
    Dec 2005
    Canada
    Thank you.
    AVCSource and ffmpegsource2 both give the same error in VirtualDub.
    (MPC displays the same error when opening the script).
    Also, can't locate the plugin LWLibavVideoSource
    try:
    reverse()
    Dec 2005
    Canada
    Which scenario is more likely: AviSynth is presenting the errors to VirtualDub or VirtualDub is creating the problem.
  6. Try
    FFVideoSource("video.mkv", threads=1, seekmode=0)
    Reverse()
  7. Originally Posted by poisondeathray View Post
    Try
    Reverse()
    Yes, that might work. But it will be incredibly slow if the video is long.
  8. Originally Posted by jagabo View Post
    Try
    Reverse()
    It's 2min14sec if mediainfo is correct (post #1)
    Your lossless I-frame encode suggestion should definitely work (and I would use I-frame, not long GOP lossless for this)
  9. Sad, I thought that AVCSource would use the same frame cache DGSource with Avisynth MT uses, but that doesn't seem to be the case, seekmode=0, with FFVideoSource like poisondeathray suggested could also help.
    LWLibavVideoSource is part of the LSMASHSource.dll -> https://forum.doom9.org/showthread.php?t=167435
    Dec 2005
    Canada
    Try
    Reverse()
    Many thanks;that worked with no blocking.
    It took 06:49 to process out of VirtualDub, without resizing, using the external mp4 codec.
  11. How long did it take normally on your setup ? (encoding without threads and seekmode, but with reverse, resulting in the "blocky" result ?)
    As jagabo alluded to, the longer the clip duration, it becomes almost exponentially slower. There is a point at which encoding to a lossless I frame intermediate will be faster
    Dec 2005
    Canada
    It took almost 14 minutes with the original script as opposed to 6:42 with the last script.
  13. Originally Posted by sambat View Post
    ???? well I'm completely confused by that . Did you mean AVCSource() for the "original script" , or FFMpegSource2() or something else
    Are you sure the encoding settings, all other conditions etc.., audio encoding, were the same ?
    Dec 2005
    Canada
    The only difference is the scripts.
    FFVideoSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv", threads=1, seekmode=0).Reverse()
  15. *gig* there are various reasons why AVCSource isn't recommend,...
  16. Don't worry , it was only for curiosity
    What I meant to compare was
    FFVideoSource().Reverse()
    VS.
    FFVideoSource(threads=1, seekmode=0).Reverse()
    Because AVCSource and FFVideoSource are using different decoders
  17. Because AVCSource and FFVideoSource are using different decoders
    not that different, AVCSource is based on an older libav version
    btw. threads=1 is probably not necessary nowadays,..
  18. Originally Posted by Selur View Post
    This is true, In my experience the older libav version neuron2 uses is much slower, and (I think single threaded) . Even years ago, when people used AVCSource vs. DirectShowSource with ffdshow (libav) , DirectShowSource was much faster
    What else can account for sambat's observed ~2x speed difference (even when ffvideosource is using threads=1, seekmode=0 !!!!!!!)
    Most of the time I would agree, but there are cases where you can demonstrate that this still makes a difference .
  19. Most of the time I would agree, but there are cases where you can demonstrate that this still makes a difference .
    haven't encountered such a case for quite some time (but I'm mainly using ffmpegsource for MPEG-4 ASP/AVC content)
    -> got an example case?
  20. Originally Posted by Selur View Post
    some interlaced avc transport streams (and even with threads=1, and other tricks like remuxing to mkv first, can still pose problems)
    For MPEG4-ASP, it usually doesn't matter in my experience, but someone was having problems the other day (it wasn't clear to me if the fix was from using threads=1, or if using the vanilla version of ffms2.dll vs. cplugin; I'm still unclear as to why he got the green frame with ffms2, I couldn't reproduce it here)
    https://forum.videohelp.com/threads/354878-Convert-AVI-to-MPEG4-AVC-always-2-lost-frames
  21. interlaced content seems to be nearly always broken when ffmpegsource is used (no matter the thread count) and the other thread looks more like a version problem :P
  22. Originally Posted by Selur View Post
    This is true but there are cases where it helps. There were examples in the FFMS2 thread.
    There are also cases where it helps with other types of files, a few posted on this board. I don't have them all archived, but you should do a search if you're still interested. Many of them had to do with seek corruption and certain ffms2 builds
    This one was actually from a thread at videohelp, I'm certain there are a few more, because I can remember them.
    http://code.google.com/p/ffmpegsource/issues/detail?id=74
    It was fixed in one of the newer revisions, but broken, then fixed again. Not sure what the current status is.
    PS. whenever there is a problem with FFMS2, first thing I do is try seekmode=0, threads=1.
    I couldn't reproduce it with or without Cplugin..so I don't know what caused or fixed it...
  23. And for interlaced AVC transport streams, DGNVTools is preferred, but alternative workaround is FFMBC lossless intermediate.
    FFMBC still handles interaced transport streams better than FFMPEG ; there was a FFMBC based FFMS2 compiled, but it doesn't have the same "magic" as FFMBC binary
  24. I've seen that "insanity detected" many times with ffmpegsource. I didn't know about the threads=1 fix. I just switched to another decoder. Just today I had that problem. I tried threads=1 and it worked. Then I updated to a newer build. And no longer needed threads=1.
  25. Originally Posted by jagabo View Post
    The "insanity detected" is a (fairly?) common example, but another one is seek corruption (macroblocking) which is sometimes fixed with threads =1
    It's hard to keep track of which version works, doesn't work. They keep on breaking/fixing things.
  26. Member
    Dec 2005
    Canada
    VS.
    03:55 and 06:13 respectively.
  27. Member
    Dec 2005
    Canada
    Continuing on, I can't get audio unless I load it separately in VirtualDub.
    Converted the AAC to AC3, to no avail.
    There is no error message, but VirtualDub file information does not show audio.
    a=FFVideoSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv", threads=1, seekmode=0).LanczosResize(640,264)
    b=FFVideoSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv", threads=1, seekmode=0).LanczosResize(640,264).Reverse()
    vid=StackHorizontal(a,b)
    #audio=ffaudiosource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv")
    audio=nicac3source("GIJoeTheRiseOfCobraTrailer-DivXPlusHD_Track01.ac3")
    audiodub(vid, audio)
    return(vid)
  28. Originally Posted by sambat View Post
    Thanks, that's more in line with expectations
    What about a simple script without reverse or filters? check info() , what does it say ?
    vid=FFVideoSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv", threads=1, seekmode=0)
    aud=FFAudioSource("GIJoeTheRiseOfCobraTrailer-DivXPlusHD.mkv")
    audiodub(vid,aud)
    info()
  29. Member
    Dec 2005
    Canada
    Audio OK.
  30. And vdub shows audio with that script loaded (file=>file information) ?
    If it does, add back the resize and reverse to vid , if audio is still ok, then add the 2nd video and stackhorizontal
