I'm trying to make a 10sec motion menu using after effects 5.0. I have a still frame as the background and two 10sec mpeg1 clips on top of the background. (kinda like chapter points) I've set the duration of the project to 10 seconds, but when I goto render, it only goes half way (5secs) and then the program freezes, and the only way I can get out is to end the task. The weird part is that when it's rendering my clips are at the end of their sequence at 5secs. (maybe that's the reason it freezes). Has anyone else had this problem?
I FIGURED IT OUT!!!!!!!!!!!! WHOOOOOHOOOOO!
When I imported the 10 sec clips into my project and render them, after effects would speed them up so that they would come out as 5 sec clips. So to fix this problem I divided the 29.97 NTSC standard FPS rate by 2 (giving me 14.985, rounded to 14.99) and made that number my frame rate. Exported as an AVI and used TMPEG to encode it into the standard NTSC DVD format. The outcome is a 10sec high quality motion menu with two video clips playing simultaneously on the same page.
Time to boast!! (I AM THE SMARTEST MAN ALIVE!!!!!!!!!!!!) char! char!
Whats the alternative to Adobe After Effects ?
By AjnabiZ in forum EditingReplies: 15Last Post: 19th Oct 2011, 17:33 -
Adobe After Effects Questions
By HoosierGuy in forum EditingReplies: 25Last Post: 2nd May 2011, 21:12 -
Replacement PC for Adobe After Effects CS5
By lowellriggsiam in forum ComputerReplies: 0Last Post: 25th Jan 2011, 10:14 -
Adobe After Effects issue
By Coroni in forum EditingReplies: 3Last Post: 22nd Oct 2010, 20:56 -
Twixtor for Adobe After Effects CS4
By Tahlos in forum EditingReplies: 4Last Post: 5th Oct 2010, 20:57
