Hello I got this video of a girl moving and I want to crop the video leaving only the girl in it so I wonder if is there a way to make the crop parameters move following a path or something like that, thanks.
another option would be adding black bars that move blackening everything but the girl
	You can use the Animate() function along with Crop(). Only a linear path will be allowed. Unless you use several Animate() calls. For example:
 moves a 640x480 box from 380,0 to 300,75 over frames 0 to 100. Be careful, YUY2 and YV12 video requires mod2 crops. You'll have to use RGB if the pan requires motion by odd numbers of pixels.Code:Animate(0,100, "crop", 380,0,640,480, 300,75,640,480) Last edited by jagabo; 1st Apr 2013 at 07:32.
  Avisynth script built in path variableBy a1s2d3f4 in forum Newbie / General discussionsReplies: 13Last Post: 29th Mar 2018, 19:15
  Help with avisynth crop commandsBy Bully9 in forum Video ConversionReplies: 9Last Post: 5th Dec 2012, 16:42
  VirtualDub File [path] does not have a video stream errorBy fershad in forum Video ConversionReplies: 4Last Post: 25th Jan 2012, 07:11
  DirectShow Error: File (path) does not have a video streamBy kstraynor in forum Video ConversionReplies: 1Last Post: 23rd May 2011, 17:44
  crop in avisynth causing tearing ?By davexnet in forum Video ConversionReplies: 13Last Post: 2nd Mar 2009, 16:17
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
