I'm editing a large DVB using Avidexux, and am using the "Shift" option in the audio settings to correct a 300ms sync problem. When I save the file the output contains no audio at all. Has anyone else had this problem?
I'm running version 2.6 of Avidemux on Windows 7.
Is the audio demuxed from the video/selecting another audio source other than the video?
Here's the output from MediaInfo:
General
Complete name : D:\Downloads\Video\Champions League Final 2012 (ITV) - Edited.avi
Format : AVI
Format profile : OpenDML
File size : 5.40 GiB
Duration : 3h 46mn
Overall bit rate : 3 418 Kbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Codec ID : MPEG
Codec ID/Info : Chromatic MPEG 1 Video I Frame
Duration : 3h 46mn
Bit rate mode : Variable
Bit rate : 3 147 Kbps
Maximum bit rate : 15.0 Mbps
Width : 704 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Active Format Description : Letterbox 16:9 image, with alternative 14:9 center
Frame rate : 25.000 fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.310
Stream size : 4.97 GiB (92%)
Audio #1
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 2
Codec ID : 50
Duration : 23s 558ms
Source duration : 3h 46mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Stream size : 311 MiB (6%)
Alignment : Aligned on interleaves
Interleave, duration : 24 ms (0.60 video frame)
Audio #2
Format : MPEG Audio
Codec ID : 50
Duration : 1mn 10s
Bit rate : 64.0 Kbps
Channel(s) : 1 channel
Stream size : 104 MiB (2%)
MPEG StreamClip - H.264 MP4 w/AC3 audio loses audio
By the_wallcrawler in forum Video ConversionReplies: 5Last Post: 25th Jan 2014, 04:05 -
Avidemux audio sync problems (shift doesn't fix it!!)
By awi1991 in forum Video ConversionReplies: 13Last Post: 20th Feb 2013, 12:49 -
Strange audio shift when using other audio track than default
By Heliooos in forum DVD RippingReplies: 2Last Post: 25th Mar 2010, 01:46 -
avidemux audio shift problem
By allenn in forum Video ConversionReplies: 0Last Post: 16th Dec 2009, 22:44 -
Audio shift problem in Avidemux
By sir_ken in forum DVD RippingReplies: 3Last Post: 18th Sep 2009, 13:25
