im trying to play my iso blu ray in my sony blu ray player using usb extrernal hard disk.
but it can't be played directly, so i need to know the procedures to make it playable in my blu ray without any quality loss..
im not familiar with a bunch of files in this iso..the only things that i think contain the video files is in bdmv folder and stream, there are lots of m2ts files split.
at first i thought i have to join the files, but it failed..i have used tsmuxer and lots of other file joiner.
at last i think i found the solution, by using makemkv software, it converts my iso directly to mkv format and i can play using my blu ray player,
but somehow the size shrink to 24 gig from roughly 45 gig..
the quality is still good, but i just want to know is there some kind of losses in my procedures.
and is mkv a blu ray format?
i want to play it without any quality loss and exactly as it is in iso.
Results 1 to 11 of 11
thanks man, so u are saying that what i have now is exactly like the file in the iso should be with no quality drop..
i asked because the original size was way bigger before.. -
*** Now that you have read me, do some other things. ***
so is there any way that i can make this file playable with my blu ray without any size shrinking
If you have an ISO, you can either:
1. Play it "as a disc" with players that support it
2. Mount the ISO (discImage), so it looks like an actual disc (to whatever system is interacting with it), and play it.
3. Extract the contents of the disc and either play or convert them.
4. Burn the ISO to disc (NOT as a file, but as a discimage) and play the burned disc.
An ISO is not a MM file format, it is a mirror image of the full contents of a physical disc encapsulated in a file. Stop treating it as if it was just another AVI/MPG/MKV, etc.
An ISO of a 1:1 ripped BD or DVD will be EXACTLY the same size as the original disc. If it isn't the same size, it's because you didn't do a 1:1 rip, you did a "Movie-Only" or similar rip, or a conversion. In those cases size usually shrinks (though, with 3DBD it could easily be larger).
Scott -
play it as a disc?
thanks scott..could u teach me how...
even after i mount it, it cant be played in my computer, power dvd said it was an unsupported format,.is it because my laptop can't read blu ray?
tried extracting them, even that does not work or im doing it wrong..
burning isn't an option as i have no blu ray burner and cd.. -
Use this prog. to mount iso: https://www.videohelp.com/tools/Virtual-CloneDrive
LG blu-ray region free - how do I burn the file to CD-rom in ISO format?
By Larrens in forum DVD & Blu-ray PlayersReplies: 4Last Post: 16th Jan 2013, 08:07 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15 -
M2TS, AVCHD, BLU RAY Playback Problem on Sony Blu Ray Players
By messi magician in forum Authoring (Blu-ray)Replies: 11Last Post: 15th Jan 2012, 19:25 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 10:37 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
