I have a dvd and i rip him with virtual dub, but i want to change something in subtitles... can somone help me...
Explaining how you ripped a DVD with Virtualdub would be a start. Did you CAPTURE it with Virtualdub? That process will not yield subtitles, unless they are turned on during capture, which will give you embedded, non-editable subs. Well, you can edit them, with a lot of time and hassle which is EASILY avoided.
Use a real ripping tool. Search in tools, on the left. -
Convert the dvd image subtitles to text first, use for example subextractor.
I try this subextractor, but they did not get the subtitles, but the subtitles are in the movie.
Are the subtitles burned in the movie? Can you deselect them in a dvd player?
Capture clips from home movie DVD's and AVI's, save as AVI
By shrimants in forum Newbie / General discussionsReplies: 2Last Post: 15th May 2012, 23:19 -
Burning AVI to DVD - AVI not viewable
By Budfudder in forum Video ConversionReplies: 8Last Post: 24th Mar 2011, 10:36 -
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45
