  1. Hi all . I recently got a mp4 video using ffmpeg( m3u8 stream). I wonder how i can remove commercials from this mp4 without losing quality and without transcoding? could you guys suggest some easy to use tools possibly free ones?Thanks
  2. you can try avidemux
    video=>copy
    audio=>copy
    format=>mp4
    mark in/out only on keyframes (not frame accurate cuts)
    For frame accuracy you need something like videoredo or solveigMM video splitter (not free)
  3. Thanks for reply . could you tell me how to use solveigMM ? which option should i use in order that quality doesn't change ?
  4. control => frame accuracy (smart mode)
    Note, this means that the quality much change for a few frames around the cutsite, because those frames must be re-encoded
    If you want absolutely no quality change, you cannot cut with frame accuracy; it's just the way long GOP compression works. You can only cut on GOP boundaries, because some frames are not entirely "complete" by themselves. They rely on other frames within the GOP
  5. Well if the frames change around the cutsite that is ok with me .
    Az long az the re encoding doesn't change quality of over all video or make the file size huge or take too much time to get final output !
    if all of the 3 above conditions comes true when using frame accuracy then i will consider using it.
    It would be nice if you tell me if these 3 conditions will be considered when using frame accuracy.
    Jan 2007
    cutting on key frames , joining using tne copy function is like cutting and splicing a film reel
    no changes in the encoding
    your cutting out commercials, chances are you can hit 'key frames' in the black out scene switch
    or be close enough tht you are not going to notice anything in the playback of the edited frame going into the blackout
    anyway commercials are usually placed at scence changes
    hardly ever in the middle of somebodies speaking part or action scence
    unless its a commercial break in the middle of sporting event
