I tried to think how I can work faster.
I realized that in order to work faster, I need to record more tapes.
To record more tapes, I need more time, I need more disk space.
So I thought - where I can get more time and how can I get more space without taking the time I need and without a hard disk with more space.
I realized that there is "time" I do not use on. and on that "time" I can not use.
Because I'm asleep or not at home or something else.
So I thought - how can I work without being at the computer.
In fact, it was easy. That I know to program scripts .. This is really not the first time I do it.
The answer is to write a script that these are the steps the script will do:
Step 1) Recording X Time i set in the script
Step 2) compression
This is the solution. If this process happens while I'm asleep or not the computer, so of course I am using in more time for compression.
But in any case I would not use that time because I had to sleep Every day
So in the end, I'm recording tape and get a small file without wasting important time
important time/usable time = time that i can be on the computer.
the goal is use the sleep time/Unusable time to make things Faster.
that script i was worked on for 5 days and may still working is about 520 lines of code.. i call it "The Magic".
i will send it to youWould you mind uploading that video sample ? If you don't want it public you can PM me
Results 31 to 31 of 31
ffmpeg conversion:audio is listed - but it doesn't playback
By sambat in forum AudioReplies: 2Last Post: 2nd Jan 2013, 14:49 -
FFMpeg Audio Out of Sync
By Endemoniada in forum Video ConversionReplies: 1Last Post: 15th Aug 2010, 21:04 -
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 01:03 -
After conversion audio is out of sync
By videojunkie7 in forum Video ConversionReplies: 0Last Post: 23rd Nov 2009, 18:06 -
Mencoder // ffmpeg flv file Audio-video sync problem
By krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 09:13
