Hi (again!). I seem to have endless bad luck with subtitles on videos I am authoring with AVStoDVD.
I have a set of subtitles in idx/sub format, but I guess there must be something wrong with the files. AVStoDVD gets as far as starting to process the subtitles, but immediately closes with the error message "PROCESS ABORTED DURING TITLE 1 SUBS (TRACK 1) ENCODING". When I choose to open the sub files with SubResync, nothing happens - no information loads at all. (I have tried with other sub files I have and they load OK, so it's not the programme that has a problem).
Any ideas how to ? I attach the first sub file (the idx file is not a valid file to upload, apparently).
Thanks,
Martin
Maybe the patch here can fix your problem.
https://forum.videohelp.com/threads/300600-SubReSync-problem
I recently had SubResynch refuse to open a SUB file and I gave up and used another program to do it, but I don't remember which program I used. Sorry. I did not know about the patch. -
Ha, funny, I found that patch only this morning. Before I applied it, SubResync wouldn't open at all. Overwriting the exe files with those from the patch cured the problem - the programme now opens just fine.
The problem is that when I choose to open these particular .sub files from the GUI, nothing happens. That's what I meant, but thanks for the reply anyway,
Martin -
Opened it with SubtitleEdit
Selected English and made OCR in 3 mins. Had "Promt for unknow words" switch off so probably a couple of "errors". Exported as idx/sub with no problems -
I have several programmes designed to transcribe/edit subtitles, but I had never installed this one before. It looks pretty much a 'must have'; the OCR is amazingly fast (once I had located a German tesseract file and installed it!) and seems very accurate. I now have an srt file and can take it from here I think!
One other question (not sure it's worth starting a new thread?). Last time I added German subtitles (srt file) to a video in AVStoDVD, all the umlauts came out on the TV as question marks; they are fine in the srt file. I redid the video, changing all the problem 'umlauted' letters to ae, oe, or ue. But I read (one of Mr.C's posts from 2009!) that I should be able to get AVStoDVD to use the vowels with umlauts.
Same with a superscripted circle for a degrees sign .... Am I missing a setting somewhere for extended ASCII characters?
Thanks again,
MartinLast edited by martinlest; 28th Mar 2013 at 15:55.
AviSynth's WavSource won't load WAVE PCM files
By random in forum AudioReplies: 7Last Post: 7th Aug 2016, 12:31 -
Four .mkv asset files won't load
By Ptaker in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 31st Dec 2012, 11:47 -
Assets won't load
By jmposing in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 25th Nov 2012, 10:00 -
Scrabble game won't load
By Psco2007 in forum Newbie / General discussionsReplies: 1Last Post: 13th Oct 2010, 20:41 -
Windows XP won't load
By Tom Saurus in forum ComputerReplies: 21Last Post: 12th Jun 2010, 10:36
