I have an MP4 file about 1hour 40 mins in length about 2mins 46 sec in a b-frame appears to be corrupt the first play about bit appears at about 2 mins 56 sec later.
I've tried to use Avidemux, Avanti, winff and TX264, h264encoder and FFMPEG directly to recover this problem.
Nothing works - does anyone know how I could recover the file - other than going back to source, if possible?
I assume that the first sentence means:
a. you have an mp4 file which is 1h 40m long (with probably MPEG-4 AVC video content, since you mentioned h264encoder)
b. this file has a corrupt Frame at around 2m 46s and the exact same Frame appears intact at 2m 56s
c. you now want to know if there's a way to replace the broken frame with a copy of the non-broken frame
am I right with this interpretation?
Assuming that is what the first sentence was ment to say:
- you can't fix this without reencoding at least the gop in which the broken frame is
- in theory one probably could:
a. detect the GOP structure of the file and the settings the first file was created with
b. open the file in an avisynth script, trim the source to the gop which includes the broken frame
c. replace the corrupt frame with a copy of the intact frame
d. reencode the new GOP
e. cut out the broken OP and replace it with the newly encoded gop (this will only work if the settings found in a. are a decent match to the original encoding parameters)
In praxis:
I don't know if your knowledge of video editing is broad enough to do this.
If the knowledge if there it's probably not really hard to do this, but from my point of view it's mainly a question of 'is it worth the effort' since doing the stuff I mentioned above isn't totally trivial and reencoding the source is probably less time consuming.
Cu Selur
merge multiple mp4(h264) video the time frame get reduce by 10%
By redsunbird in forum Video ConversionReplies: 2Last Post: 15th Dec 2012, 03:32 -
How to repair (close) GoPro MP4 video file?
By AlainW in forum Newbie / General discussionsReplies: 1Last Post: 3rd Aug 2011, 06:00 -
Recovered Mp4 video not playing, any hope of repair ?
By Pintofshite in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2011, 10:50 -
Video too fast (frame rate?): FLV to MP4 with Ripbot
By JesterPoet in forum Video ConversionReplies: 4Last Post: 19th Nov 2010, 14:41 -
MP4 corruption Need Help
By yus in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2010, 13:37
