I'm trying to convert an AVI file to WMV format using Windows Media Encoder 9. I have two machines - WinXP Pro 32 and Win7 Pro 64 - with Windows Media Encoder 9 and K-Lite Codec Pack installed on both machines. Basically, everything is "identical" between these machines as much as it can be considering that one is XP 32 and the other is 7 64.
When I convert a video on the WinXP machine, everything works fine - the audio level bars in WME jump up and down during encoding and the final resultant WMV file has audio. Meanwhile, when I attempt to covert the same video using the same conversion settings on the Win7 machine, the audio level bars in WME remain at zero at all times and the resultant file has no audio.
I use identical conversion settings on both machines: conversion for Windows Media Server (streaming), DVD quality video (CBR), CD quality audio (CBR), no resizing of the input.
On both machines the FFDShow Audio icon appears in the tray during the conversion process. If I open the FFDShow Audio config dialog during the conversion process on Win7 machine, it shows some dynamic decoding statistics, which seems to imply that the audio codec is "working". Nevertheless, the audio never reaches Windows Media Encoder (audio level bars remain at zero) and the result has no sound.
On both machines the original video plays fine (i.e. with sound).
This is probably a very basic question, but what am I doing wrong? Is this caused by the Windows Media Foundation architecture in Windows 7? How can I make Windows Media Encoder 9 work under Windows 7?
Hi,
When you say you're "using the same conversion settings" on the Windows 7 machine, do you mean you've saved the WME session file on the XP machine and copied it to the Windows 7 machine where you've opened and started using it? As you probably know, finger trouble can cause a lot of differences otherwise
A couple of things you might check in WME at this point
- View>Properties Panel
- Sources tab>Audio: checked
- Compression tab>Edit>Media types>Audio: checked
- Plug-ins tab: nothing configured that would mute audio
Francois - View>Properties Panel
windows media encoder plugins
By river3 in forum Video Streaming DownloadingReplies: 0Last Post: 4th Jun 2010, 03:15 -
Windows Media Encoder Question
By Gabaldad in forum Capturing and VCRReplies: 5Last Post: 24th Sep 2009, 17:48 -
Windows Media Encoder Crashes
By musomn in forum Video ConversionReplies: 3Last Post: 27th May 2009, 20:00 -
How Windows Media Encoder Works
By i-developer in forum Video Streaming DownloadingReplies: 1Last Post: 20th May 2009, 19:21 -
Why is there no sound when recording with Windows Media Encoder?
By WaiLoungChan in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 01:51
