I have a blu-ray/dvd player that will only play videos with certain codecs...primarily xvid. I have a large video library of avi videos that i am converting /recoding to either mkv or avi but with the xvid codec..i have tried many commercial and free video conversion programs (Aimersoft video converter, E.M. Total Video Converter, FreeMake video converter,handbrake, etc. )
No matter which i use the end result of the converted video has an odd "slow motion" effect or something (hard to describe)...what i mean by that is, for example, that in cases where there would be a scene with some fast motion, that motion is somewhat slowed down in the converted video..no matter what conversion program i try, i get that result..i've tride manually adjusting framerate, and other manual settings...with no luck.
When i use a manual override instead of presets, i use xvid as the codec,, 23.97 as the framerate, and because i'm trying to reduce the quality slightly (so as to reduce the file size to around 700mb or so) i use a video bit rate of 1200kbps..and am always converting the audio to mp3.
anyone have any idea why i keep getting that slow motion effect in the converted videos? I use mediatab and the before and after framerate is the same.
Thanks for any thoughts you might have.
Brian
Results 1 to 12 of 12
.....along with posting your player model/make.
Other members here might possibly have your same player. -
The player doesn't matter, i have both a sony Blu-ray player (BDP-BX59) and a samsung and i primarily use VLC media player on my computer...no matter what player (sony or samsung blu-ray or pc with VLC or windowxs media media player) the converted video looks choppy or lagging in the video..and sometimes the audio is out of sync as well..on the framerate, i have used the option to keep the original framerate and have also just looked at the original framerate in the original movie file and manually set it to that same framerate when converting..it doesn't seem to matter.
I convert these videos from my dvd/bluray collection so i can have them on a large hard drive i have hooked up to the bluray player for vidoe streaming...(easier than messing with a bunch of disks...)..the original unconverted mkv file worked on my old player fine but the new player doesn't support the codec - so i converted to avi/xvid.
Here is the output of the mediatab analysis of the original move before converting..it was an mkv format before, and i was converting to avi with xvid codec..
as you can see from the sample the motion looks slow or choppy, the motion is not smooth as in the original.
===================== General =====================
Complete name : F:\convert\movie1.mkv
Format : Matroska
File size : 699 MB
Duration (ms) : 1h 39mn
Total bitrate : 982 Kbps
Movie : movie1
Encoded date : UTC 2012-07-15 08:09:33
Encoded application : mkvmerge v5.6.0
Encoded library : libebml v1.2.3 + libmatroska v1.3.0
===================== Video =====================
Format : AVC
Format info : Advanced Video Codec
Format profile : High@L3.1
Use of CABAC : Yes
RefFrames : 3 frames
Format settings - GOP : M=1, N=5
Muxing mode : Container profile=Unknown@3.1
Codec Id : V_MPEG4/ISO/AVC
BitRate_Nominal/String : 942 Kbps
Width : 1 280 pixels
Height : 544 pixels
Aspect ratio : 2.35:1
Framerate : 23.976 fps
Colorimetry : YUV
Colos space : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.056
Encoded library : x264 core 80 r1376M 3feaec2
Encoded library settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / wpredb=1 / wpredp=2 / keyint=250 / keyint_min=25 / scenecut=40 / rc_lookahead=40 / rc=2pass / mbtree=1 / bitrate=942 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
===================== Audio =====================
Format : AAC
Format info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Format settings - SBR : Yes
Format settings - PS : No
Codec Id : A_AAC
Channel(s) : 2 channels
ChannelPositions : Front: L R
Sampling rate : 48.0 KHz
===================== Text =====================
Format : UTF-8
Codec Id : S_TEXT/UTF8
Codec info : UTF-8 Plain Text
Language : English
Here is the output of mediatab after trying to convert and using the xvid codec:
Count : 267
Stream count : 1
Kind of stream : General
Kind of stream Id : 0
Video count : 1
Audio count : 1
Video formats : MPEG-4 Visual
Video_Format_WithHint_List : MPEG-4 Visual (XviD)
Video codecs : XviD
Audio formats : MPEG Audio
Audio_Format_WithHint_List : MPEG Audio (MP3)
Audio codecs : MPEG-1 Audio layer 3
Complete name : F:\convert\movie_converttry1.avi
Folder name : F:\convert
File name : movie_converttry1.avi
File extension : avi
Format : AVI
Format : AVI
Format info : Audio Video Interleave
Format extensions : avi
Format comercial name : AVI
Format profile : OpenDML
Internet media type : video/vnd.avi
Interleaved : Yes
Codec : AVI
Codec : AVI
Codec info : Audio Video Interleave
Codec extensions : avi
File size : 1663894394
File size : 1.55 GB
File size : 2 GB
File size : 1.5 GB
File size : 1.55 GB
File size : 1.550 GB
Duration (ms) : 5973557
Duration (precise) : 1h 39mn 33s 557ms
Duration : 1h 39mn
Duration : 01:39:33.557
Total bitrate : 2228346
Total bitrate : 2 228 Kbps
Stream size (bytes) : 72543850
Stream size : 69.2 MB (4%)
Stream size : 69 MB
Stream size : 69 MB
Stream size : 69.18 MB
Stream proportion : 0.04360
Created date (UTC) : UTC 2013-03-28 05:54:35.518
Created date : 2013-03-27 23:54:35.518
Modified date (UTC) : UTC 2013-03-28 07:27:06.204
Modified date : 2013-03-28 01:27:06.204
Count : 182
Stream count : 1
Kind of stream : Video
Format : MPEG-4 Visual
Format comercial name : MPEG-4 Visual
Format profile : Simple@L3
Format settings - BVOP : No
Format settings - QPel : No
Format settings - GMC : 0
Format settings - GMC : No warppoints
Format settings - Matrix : Default (H.263)
Internet media type : video/MP4V-ES
Codec Id : XVID
Codec : XviD
Codec URL : http://mediaarea.net/XVID
Codec : XVID
Codec : XviD
Codec family : MPEG-4V
Codec info : XviD project
Codec URL : http://www.xvid.org/Downloads.15.0.html
Codec/cc : XVID
Codec profile : Simple@L3
Packet BitStream : No
Codec settings - BVOP : No
Codec settings - QPel : No
Codec settings - GMC : 0
Codec settings - GMC : No warppoints
Codec settings - Matrix : Default (H.263)
Duration : 1h 39mn
Bitrate : 2083432
Bitrate : 2 083 Kbps
Width : 768
Width : 768 pixels
Height : 576
Height : 576 pixels
Pixel aspect ratio : 1.000
Aspect ratio : 1.333
Aspect ratio : 4:3
Framerate : 23.976
FrameRate_Original : 23.000
FrameRate_Original/String : 23.000 fps
Frame count : 143222
Resolution : 8
Resolution : 8 bits
Colorimetry : 4:2:0
Colorimetry : YUV
Colos space : 4:2:0
Bit depth : 8
Bit depth : 8 bits
Interlacement : PPF
Interlacement : Progressive
Bits/(Pixel*Frame) : 0.196
Delay : 0
Delay : 00:00:00.000
Stream size (bytes) : 1555687696
Stream size : 1.45 GB (93%)
Stream size : 1 GB
Stream size : 1.4 GB
Stream size : 1.449 GB
Stream proportion : 0.93497
Encoded library : XviD0050
Encoded library : XviD 1.2.1 (UTC 2008-12-04)
Encoded library name : XviD
Encoded library version : 1.2.1
Encoded library date : UTC 2008-12-04
Count : 149
Stream count : 1
Kind of stream : Audio
Format : MPEG Audio
Format comercial name : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Format settings : Joint stereo / MS Stereo
Format settings mode : Joint stereo
Format settings mode extens : MS Stereo
Internet media type : audio/mpeg
Codec Id : 55
Codec : MP3
Codec URL : http://www.iis.fraunhofer.de/amm/index.html
Codec : MPA1L3
Codec : MPEG-1 Audio layer 3
Codec family : MPEG-1
Codec info : MPEG-1 or 2 layer 3
Codec/cc : 55
Codec profile : Joint stereo
Duration (ms) : 2228928
Duration (ms) : 37mn 8s
Duration (precise) : 37mn 8s 928ms
Duration : 37mn 8s
Duration : 00:37:08.928
Bitrate mode : CBR
Bitrate mode : Constant
Bitrate : 128000
Bitrate : 128 Kbps
Channel(s) : 2
Sampling rate : 48000
Sampling count : 106988544
Delay : 0
Delay_Source : Container
Delay : 0
Delay : 0
Stream size (bytes) : 35662848
Stream size : 34.0 MB (2%)
Stream size : 34 MB
Stream size : 34 MB
Stream size : 34.01 MB
Stream proportion : 0.02143
Alignement : Aligned
Alignement : Aligned on interleaves
Interleaved : 1.54
Interleave duration : 64
Interleave duration : 64 ms (1.54 video frames)
Encoded library : LAME3.98.2
Encoded library : LAME3.98.2 -
the frame rate of the input (F:\convert\movie1.mkv) is 23.976 fps the frame rate of the video stream of the output (F:\convert\movie_converttry1.avi) is 23 fps:
Framerate : 23.976 fps <- this is the frame rate written in the container header
FrameRate_Original/String : 23.000 fps <- this is the frame rate the video stream actually has
-> you are definitely doing something wrong during the conversion
Cu Selur
Ps.: smrpix was faster,.. + only way to fix this is to reencode the source with proper settings -
Some samsung players are restrictive in playable resolution
Width : 768 pixels
Height : 576
W = 720 to match 576h -
why are you changing the frame rate
you can reduce file size and quality just by changing the bit rate
that is your problem 'messing with the frame rate'
it appears that the conversion process is simply dropping one frame worth of data change , which creates the choppy effect when jumping over the missing frame to the next frame
removing frames is harder to do than adding frames, which interpolates data and adds extra fields/frames
removing only 1 frame is difficult, easier and smoother to cut frame rate in half
leave the frame rate alone just reduce video to bit rate if you want a smaller file
edited typo'sLast edited by theewizard; 28th Mar 2013 at 20:32.
Is very necessary convert movies?? Because you can install a SERVIIO on your PC and play all files (virtually, of course).
Claudio
Frustration with Toshiba D-VR7 - why?!?!
By ottawadave in forum DVD & Blu-ray RecordersReplies: 7Last Post: 22nd Mar 2012, 00:38 -
My Computer Project = frustration
By jollyjohn in forum ComputerReplies: 36Last Post: 31st Mar 2011, 10:17 -
AC-3 and Wave 5.1 frustration revisited...
By takearushfan in forum AudioReplies: 32Last Post: 19th Aug 2010, 13:54 -
Audio/Video Synchronization Frustration
By DrNyquist in forum Capturing and VCRReplies: 9Last Post: 18th Feb 2010, 19:23 -
Video Work frustration
By bja5150 in forum Video ConversionReplies: 3Last Post: 18th May 2008, 14:08
