I use MKVMerge to split large mkv files so that I can put the video on a FAT32 flash drive and play it with my Sony BD player. Never had an issue of replaying properly - until now. I have tried multiple times to split this particular 8.5GB file down to three 2.9GB parts. I link each of the parts for seamless replay (at least near seamless). But, with this video when the first part ends and the second part begins I loose the video while the audio works. Same if I try to start with part 2 or part 3, I only get the audio. Only part 1 properly replays the video and audio components. Also, if I play the three part version on my computer there is no issue as all works as expected.
Does anyone have an idea what may cause this?
Thank you.
Just reformat your flash drive to ntfs format and put the whole file there with out splitting it.
If you want to give the split method another try, this product gets mentioned often on this forum:
https://www.videohelp.com/tools/SolveigMM-AVI-Trimmer -
Problem might simply be that due to the inherent remuxing during the splitting some container tags changed, see: https://trac.bunkus.org/wiki/FAQ%3AImprovingPlaybackCompatibilityWithPlayers to figure out which settings might be the problem.Yes, it works correctly on my computer. Any thoughts?
johns0
Thanks for obvious solution. For some reason I had it in my mind that the BD player required FAT32 formatting on the flash drive. I looked where I thought I had seen that spec, but couldn't find it again so reformatted the flash drive to NTFS and it works perfect.
Many thanks.
How to split 8.71Gb mkv video file?
By alegator in forum EditingReplies: 7Last Post: 29th Jul 2010, 07:51 -
trying to split and play .mkv video file
By Chrys in forum Newbie / General discussionsReplies: 2Last Post: 27th Jan 2010, 10:07 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 11:28 -
How do I split my 8gb MKV file in half?
By y0ungSir in forum Newbie / General discussionsReplies: 9Last Post: 1st Jul 2009, 15:36 -
How do I split .mkv file to two parts?
By dilanalex in forum EditingReplies: 1Last Post: 8th Apr 2009, 03:08
