I don't have the Firewire cord for this Canon HV-20 to connect it to my MacBook. I'm just wondering what this plug is called so I can order it. I have a photo here. I need to know what the component out is called so I can order the plug..........Anyone? PHOTO INCLUDED
THANKS FOR YOUR TIME!
Results 1 to 9 of 9
That's not the firewire connector, you will notice it says component out which is a canon proprietary cable. There is a standard 4 pin firewire connector elsewhere on your camera. You will need a 4 pin to 4 pin or 4 pin to 6 pin depending on what the connector on your mac is -- unless it's firewire 800 in which case you'll need a 400-800 adapter as well.
Any decent electronics or video store will have it. Don't overpay.Last edited by smrpix; 26th Mar 2013 at 19:16.
A good place to buy a cable is Monoprice.com. Take a look at this link and check out whether this cable will work for you:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10301&cs_id=1030104&p_id=...seq=1&format=2
Brainiac -
the firewire port on a canon hv20 is on the back next to the battery under a long cover.
It should but I can't guarantee it. I have been using it to connect old FireWire HDs to new TBolt-equipped Macs. The only thing that hasn't worked perfectly is one 2.5" enclosure which, apparently, requires more power than TBolt is willing to give it through the FW adapter. In this case I had to either provide power (there's a 5V jack) or use the enclosure's USB2 port (which, of course, doesn't use TBolt at all).
...{time passes}
Just checked at the Apple Store Online. There is one reviewer who says he could not get the adapter to work with his camcorder (didn't specify which one) and FCPX. Here's the Apple webpage which details which camcorders work with FCPX: http://help.apple.com/finalcutpro/cameras/en/index.html?
I needed to capture some old VHS tapes into my Mac and found that "recDV" (http://www.macupdate.com/app/mac/26065/recdv) worked with my Sony DVMC-DA1(analog>digital converter). No video preview while capturing (just audio) but the audio did tell me that it was coming across. It worked fine. This app along with the Tbolt>FW adapter (and the appropriate FW800-4pin cable) should do the job for you.
Canon HV40 not recognized via firewire
By ThanosK in forum Capturing and VCRReplies: 16Last Post: 30th Dec 2012, 09:54 -
Jittery HDV Capture To Sony Vegas 12. Canon Vixia HV30 Via Firewire.
By epu in forum Capturing and VCRReplies: 1Last Post: 20th Aug 2012, 20:38 -
Firewire capture fom Canon HV20
By johnwc in forum Newbie / General discussionsReplies: 8Last Post: 6th Jul 2010, 09:59 -
4-pin firewire ruined my Canon HV20
By Big Chupa in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 12th May 2010, 12:20 -
FireWire to Kino/dvgrab from Canon ZR70MC ??
By jdetwile in forum LinuxReplies: 6Last Post: 27th Aug 2008, 11:14
