Hey all
Okay, here is my newest dilemma
I have a video game system that has ONLY component output, no HDMI, no DVI, etc.
Now I need to hook it up to my LED/LCD HDTV that I bought about 2 years ago, in my living room.
The problem is, when I looked behind it, then checked the owners manual, it only has VGA, DVI & HDMI inputs!!
WTF?!?!
ARRRGGGG!!!!!!
So I was checking out some various solutions to convert it to one of the inputs I do have, preferably DVI or HDMI.
I do not need it to do any kind of upscaling, just to pass it through from Component to one or the other.
http://www.ebay.com/itm/DVI-to-Component-Video-Adapter-/150954991798?pt=US_Video_Cable...item23259e60b6
http://www.ebay.com.au/itm/Hama-DVI-I-3-RGB-YUV-Component-Plugs-Adapter-Cable-/1905073...d=461477278785
http://www.ebay.com/itm/Fosmon-Component-RGB-to-HDMI-Converter-v1-3-HDTV-with-R-L-Blac...item48536386e3
I read where the last one I posted worked for someone using their PS3, why you would not just get an HDMI cable I don't know, as I am sure the PS3 is new enough to have an HDMI port on it.
Anyways, can anyone give me a nudge in the right direction as to what would be good to use ?
Audio does not matter as I will be using a optical digital cable for that, just the video.
Thanks!
Results 1 to 1 of 1
LED MONITOR - HDMI to DVI-D cable, HDMI media player not working?
By krishn in forum DVB / IPTVReplies: 16Last Post: 25th Feb 2012, 17:20 -
Plug DVI/HDMI adapter to DVI video card?
By Stealth3si in forum Media Center PC / MediaCentersReplies: 25Last Post: 23rd Dec 2010, 20:32 -
Connect VGA/DVI/HDMI source to Component HDTV
By jstewar9 in forum Media Center PC / MediaCentersReplies: 0Last Post: 13th Jan 2010, 16:11 -
DVI - HDMI - DVI problem
By rbjt in forum Media Center PC / MediaCentersReplies: 0Last Post: 5th Aug 2009, 00:14 -
Composite to HDMI/DVI/component Conversion
By Gromit137 in forum DVB / IPTVReplies: 3Last Post: 30th Oct 2008, 12:10
