Results 1 to 10 of 10
    Dec 2007
    Greece
    Guys i want to put in a mkv file, ass subtitle file (made with aegisub of course) but when i do that with mkvmerge GUI the script that contains the ass file does not work.
    Is there any way to do it as softsub?
    Thanks in advanced
    Oct 2005
    666th portal
    convert the ass to srt. maybe aegisub or subtitle workshop.
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    What does the script in question do? Can you add the .ass subtitles to the .mkv video manually?
    Dec 2007
    Greece
    script such as fade in/out the subtitle, change color, position, gradually changing size etc
    If i'll merge it in the movie works as a simple srt file.
  5. the script that contains the ass file does not work.
    post the script that does not work
    Dec 2007
    Greece
    {\fad(1000,500)\pos(353.867,108.396)} blah, blah blah
    either fade neither position do work
  7. what are you using for playback?
    Dec 2007
    Greece
    MPC home cinema.
    I thought what if i convet (if there is a way) the ass file to sup and then i merge it with the mkv file.
  9. Have you tried to use xy-vsfilter instead of the internal subtitle handler of MPC-HC?
    if you use the internal filter make sure that:
    a. View-> Options-> Playback-> "Auto-load subtitles" is ticked
    b. View-> Options-> Subtitles->"Allow animation when buffering" is ticked
    otherwise fade&co will not be shown.
    Cu Selur
    Dec 2007
    Greece
    They r already ticked long before
