hi there i am a linux user
i and i looking for a tool to blueray authoring and burning for linux
that will put 2 or 3 movies on to blueray disk with menus
any help with this would be great
tia
jet
Check out this link:
https://irishjesus.wordpress.com/2010/10/17/blu-ray-movie-authoring-in-linux/ -
Looks like diprotic's link has an extremely convoluted way you can make discs, but you'll have to live without menus if you insist on doing this under Linux.
I'm not Microsoft fan. I make my living supporting Linux servers. But Windows is where the tools are and because of that, it's what I (grudgingly) run at home on my PC. -
i have tried using multiavchd and avchdcoder on windows but i get a tsmuker has stopped working error
i have tried reistalling both programs and ever tried replace tsmusker still not work tried diff codec aswell -
i got no prob using windows to convert its just they programs will not work tsmuker crashes on both programs
but if i download tsmuker and run it it works i have tried to replace it but nothing is working some one please know what i can do -
1) You can do it under Windows. Install a virtual machine and run Windows in that. There's a reason why BluRay authoring is done under Windows. You are experiencing why firsthand.
2) You can continue to beat your head against a wall and perhaps a few years from now someone will care enough to get this working under Linux.
Your decision.
I second what El Heggunte said. Amazing.
blueray movies without blueray burner
By piano0011 in forum Blu-ray RippingReplies: 7Last Post: 30th Jan 2013, 23:45 -
Searching Freeware for DVD-AVCHD (mini Blueray) Authoring
By benji179 in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2010, 13:17 -
LINUX: AVI to DVD Encoding and Authoring : BASIC
By disturbed1 in forum User guidesReplies: 13Last Post: 5th Feb 2010, 20:43 -
DVD authoring - linux
By andreltr in forum LinuxReplies: 6Last Post: 24th Jun 2009, 12:58 -
DVD Authoring in linux
By ronnylov in forum LinuxReplies: 6Last Post: 20th May 2008, 05:00
