I capture videos from my svhs-cam via pc-card (haupauge) with divx with the 576x432 resolution for PAL. The results are OK.
Now I would like to create SVCD from my DIVX-videos.
I am a little confused about the svcd-resolution for PAL (480x576) , bacause it isnīt a 4:3 format.
My questions:
1. Whats the reason ?
2. Can I convert my videos (divx 576x432) to SVHS
3. Make it sense to capture in divx with 480x576 resolution (but in this case the divx wouldnīt show the correst video (4:3)
4. What would be the best format to capture my videos
1. the svcd bitrate is too low for any higher resolutions like dvd. it will look okey on your dvd player or software dvd player if you encode with 4:3 aspect ratio, the player will "stretch" the picture to correct aspect ratio.
2.svhs? yes if you have a tvout or copy from your dvdplayer.
3.no, capture in a more lossless codec like mjpeg or huffyuv to acheive better quality.
4.uncompressed or huffyuv.
Video Converters that supports most video formats, RM, FLV, WMV, MOV, MP4
By Baldrick in forum Video ConversionReplies: 134Last Post: 31st Mar 2021, 10:27 -
video formats
By hawkeye48 in forum Newbie / General discussionsReplies: 10Last Post: 15th Jan 2011, 09:17 -
multicamera video montage with different source fps and video formats...
By foler in forum EditingReplies: 2Last Post: 16th Feb 2009, 04:19 -
* * * Different Video Formats * * *
By wookie1820 in forum Video ConversionReplies: 3Last Post: 20th Mar 2008, 11:23 -
rm video formats
By bharathi_n_r in forum Newbie / General discussionsReplies: 5Last Post: 30th Nov 2007, 23:40
