Hi Folks,
I'm making a DVD of a live concert from a friend's band and I'd like to find an Opensource / if not Freeware / if not Trialware that has the following functions :
- Can make a chapter menu (I have only 1 big title, I need a chapter menu)
- Can give names to chapters
- Can make menu quite easy with the title of the chapter (and maybe screenshot also)
I tried :
- DVDFlick : no go, unless I split the video in parts and reunite them in DVD flick as video sources.
- AVS2DVD : no chapter menu (the author told me)
- DVDStyler : seems doable but with no text and no automatic menu
- Gui for DVDAuthor, DVDAuthorGui : same as DVDStyler
So, any advice on a DVD aithoring software that does this ?
Thanks !
fredo46
Results 1 to 16 of 16
I use DVDAuthorGUI. I mean, how hard is it to create simple title and menu BMPs using some photo app? Then you use DVDAuthorGUI to convert them to M2Vs for the menu backgrounds. That part is in Menu->Create M2V Still. The best menus come from your imagination, not some stupid program template.
I have one video source with 25 chapters, for each one I want a screenshot and that in several menu pages. But of course a friend and I made the visuals for the menus. But we don't want to spend 2 days making 3-4 menu pages that could easily be done automatically.
By the way, TMPGEnc Author doesn't allow to add custom backgrounds ! So I can't use it, damn. Gonna try AVCHD again, then. -
And with a freeware program? Good luck finding one. You might check out DVD-Lab Pro. I don't know if the trial version is complete, but it's well-thought of around here as being a full-featured program. But I wouldn't expect a free program to take your pictures and crop/resize/arrange them nicely on some sort of a background to be used as menus. There are many around here with knowledge of photo programs, NLEs, and/or AviSynth that could take your pictures and make your menus in a couple of hours.
DVD Lab Pro has fully functional trial, it can generate chapter menus for movie with thumbnails, you can change those generated thumbnails by dragging frame from preview window, you can also change backgrounds.
Well, DVDFlick (and DVDStyler also, I think) does exactly that but only for titles, not for chapters. So I thought it might be possible for another freebie ?
I'll try DVDLab Pro. Thank all of you for you help ! -
I am using the latest version, called TMPGEnc Authoring Works 5.
To change the background of a menu do the following:
1. Import your clips and add the chapter markers.
2. Create a custom menu or use a template if you wish.
3. When you are done creating your menu(s), you will be presented with a screen showing you all of the menus associated with the project. Double-click on any of the menus displayed.
4. Click the EDIT MENU button on the screen that opens up. A dialog box will appear; click on BACKGROUND AND AUDIO SETTINGS.
5. Under PICTURE FILE SETTINGS, click the BROWSE button. Then browse you computer and choose the background you wish to use. Click OK.
6. If you are using a motion background, then click DVD-VIDEO GLOBAL MENU SETTINGS. Click the MOTION MENU tab. Click the MOTION MENU (NO AUDIO) radio button or the MOTION MENU AND BACKGROUND AUDIO radio button. Set duration of the menu in the BGM/MOTION MENU DURATION box. Click OK.
7. If you click the SIMULATION button and you want to see the motion menu in action, just click the MOTION button on the DVD controls on the bottom of the screen. That will render the motion background.
You will have to do steps 3-5 for each menu. This is only a brief list of steps; there are more things you can do. Just experiment.
Brainiac -
Seeing you're still considering alternative tools, let me mention that I've used GUI for dvdauthor for all you mention and more (even custom DVD virtual machine programming and register manipulation). It's not that intuitive to get going with, but at the time I evaluated it, its levels of control and flexibility were unmatched in freeware. Glad you managed, though.
DVD authoring failed, advice?
By Elevenius in forum Newbie / General discussionsReplies: 12Last Post: 8th May 2011, 14:06 -
Disc writing tool not working in TMPGEnc dvd authoring 4
By egor909 in forum Authoring (DVD)Replies: 3Last Post: 22nd Nov 2009, 05:14 -
authoring tool for HD video -> DVD
By feh in forum Authoring (DVD)Replies: 2Last Post: 13th Jan 2009, 14:03 -
newbie question: need freeware DVD authoring tool
By kbflower in forum Authoring (DVD)Replies: 7Last Post: 20th Jul 2008, 20:45 -
Which DVD Authoring Tool ?
By Leo48 in forum Authoring (DVD)Replies: 5Last Post: 1st May 2008, 15:37
