I'm editing DVB streams with Avisynth in order to make some good quality chapters from my favourite series.
And i also want to merge the teletext subtitles (converted to text sub) in the MP4 file, but i dont know how to trim the same way Avisynth trim the audio and video streams.
I mean, i convert the video and then i convert two audio streams, ok, i use the trim function and all goes ok. But then i can only import subtitles in the final file and they wont be sync because video is not full-lenght.
I can use VSFilter to render the subtitles in the video and they will be synced, but i dont want hard-subs. Thats my problem. Is there any way to export trimed subtitles based on Avisynth script (without been rendered on the video stream)?.
Thanks!.
	I don't know the Spanish DVB standard but if the original DVB file consists of MPEG2 video plus audio AC3 or whatever and teletext subs you could use ProjectX to edit and demux. This would maintain subtitle sync SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851
	Yes but if i trim the video using Avisynth subtitles wont be synced (coz video is trimmed).
 I've found an phyton script that do the work based on avs script (well, it just take the trimmed frame data). As far as i tested it works ok.
 https://github.com/vdcrim/TrimSubs
  Trim a part of avi, how do subtitles work?By indijay in forum Video ConversionReplies: 2Last Post: 17th Dec 2012, 15:39
  How do I trim audio with AVIsynth?By Nagashi in forum AudioReplies: 4Last Post: 2nd Oct 2011, 11:13
  About TRIM and SubtitleBy DruidCtba in forum SubtitleReplies: 1Last Post: 3rd Feb 2011, 11:52
  AVI TrimBy drgt in forum Newbie / General discussionsReplies: 6Last Post: 13th Nov 2010, 05:36
  How to trim wmv-hd?By daz2712 in forum Blu-ray RippingReplies: 2Last Post: 26th Aug 2009, 10:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
