  1. Member vhelp's Avatar
    Mar 2001
    New York
    i'm trying to calculate the duration in microseconds (µs) the same way that virtualdub (information screen) calculates it but am having trouble getting the algo to properly show 33667µs.
    29.970 fps = 33667µs
    23.976 fps = 41708µs
    25.000 fps = 40000µs
    given dwScale=1001 (for video/interlace) and dwRate=30000 written to the avi header comes out wrong:
    1001 * 30.000 = 33.3667
    1000 * 29.970 = 33.3667
    1001 * 29970 = 0.0334
    1000 * 29970 = 0.0334
    i know i can just hold the values in a list internally but i need it to calculate in case the framerate is different and wouldn't be in a list.
    this is for a raw bmp2avi app i'm working on and want to show this value in the gui when the user sets the parameters up. thank you.
  2. Why don't you just look at the VirtualDub source? And µs is microseconds (1/1000000), not milliseconds (1/1000). It looks to me like it's simply scale/rate * 1000000. I think "29.970 fps = 33667µs" is a typo on your part:
    That was from a file with rate=30000, scale=1001. 1001 / 30000 * 1000000 = 33367 rounded to the nearest microsecond.
  3. Member vhelp's Avatar
    Mar 2001
    New York
    [solved]
    thank you for the tip, jagabo. i knew i would have to trial and error until i finally figured it out.
    procedure TForm1.cbxFrameRateChange(Sender: TObject);
    begin
      case cbxFrameRate.ItemIndex of
        2: sb1.Panels[0].Text := inttostr(round( (100100/24000000)*10000000 ))+'µs'; //film,  41708µs
        5: sb1.Panels[0].Text := inttostr(round( (100101/30000000)*10000000 ))+'µs'; //video, 33367µs
      end;
    end;
