Up until recently I've been burning most of the CDs I still make for my truck from FLAC files using Nero 9. I just tried to burn one from a set of M4A files I had made using dbPowerAmp and the Nero AAC codec. Nero 9 crashes every time I try to load one of these files. They play fine in all programs I've tried and burn fine in Burrrn as well. I've tried several decoders in the Nero plugins folder with no success. I'm using a combination of MadVR and LAV Filters for most of my directshow decoding. I previously had FFDSHOW so maybe the change in filters is causing an issue? Any input is appreciated.
Results 1 to 9 of 9
1) Try reinstalling Nero. Sometimes it just gets flakey until you reinstall.
2) If that doesn't work, install the free ImgBurn. It can burn audio CDs and convert various formats to standard audio CD. But... you need to search for a guide on how to burn a true audio CD with it because if you just wing it, there's a chance that you'll end up burning a data disc. I don't use ImgBurn for audio CDs (I actually use Nero for that because I prefer Nero's interface and options for this task) so all I can tell you is that I looked it up once and I felt that it was fairly non-intuitive to get it to burn a true audio CD instead of a data disc, but it can do it.
One more thought - can you rename your M4A files to end in AAC instead? Nero may be having problems with that M4A name. -
Sorry - another "one more thought". Humor me. Rename the files to AAC. Don't post back about how "I know that M4A is OK because blah blah blah". Just do it. Rename one and see if it fixes the issue. It's easy enough to rename one file and test this and if it fixes your problem, that's easy and fast and requires no reinstall or installation of a new program.
I renamed one of the files to an aac extension. Nero crashed with some odd error about a 2 second minimum file length. Then it restarted itself. I tried it again and it loads the aac file fine. It still doesn't like M4A though.
Where would the Nero log file be located? I've checked the program folders and the AppData folders to do avail so far. -
Nero log location, W7: Program Files>Nero>Nero 7>Core>NeroHistory
One explanation of interpreting the log: http://forum.digital-digest.com/f57/faq-burning-nero-failed-some-clues-why-45942.html
The log may not help you, but I usually find some errors that point in the right direction there. You can also post the entire log here if you like. -
Renaming the files works, but it isn't a fix. It's a work around. I have thousands of M4A files that I'd rather not go through and rename. I'd rather get Nero working correctly. For now I'll use Burrn to make a disc if I need to.
No such folders seem to exist for the log files in Nero 9. I'll just try reinstalling it if I can ever find my original installers. -
I just tried this again on Nero 11 with the same results. FLAC wouldn't load either until I added the nxmyfla.dll file to the plugin folder. Then it opened FLAC fine. Adding the nxmyacc.dll files lets it open AAC fine but still not M4A even though it's listed as a supported format. I'll figure it out eventually.
.aac to .m4a.. possible?
By romi7519 in forum AudioReplies: 35Last Post: 14th Dec 2018, 06:45 -
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 09:41 -
M4a to AAC Converter
By Dave1024 in forum AudioReplies: 6Last Post: 27th Jul 2009, 22:44 -
Modifying headerinformation in aac *.m4a files
By chh in forum AudioReplies: 4Last Post: 18th Jul 2009, 12:47 -
MP4 (x264 / AAC / 720x480) to MP4 (x264 / AAC / iPod res)
By GrayStrickland in forum Video ConversionReplies: 2Last Post: 15th Jun 2009, 11:20
