I want an application just to track the editing marks where i want to cut, to fade, to speed up ... dont know. It should be useful if it can allow hotkeys to set the same hotkey as recording start (in other software) and other to set every time mark.
Any idea of free, portable, light software like this?.
What solution do you use for track the editing points?.
Thanks!.
Huh??
What are you trying to do: see how fast you can make an edit?
Are you just wanting a good editing software that allows you to place markers?
More info needed...
Scott -
Haha, no no.
I just want to mark some points of the video in order to remember where i have to edit. I mean, like dying in a game and marking this time in order to cut the rest of the video reaching this point again. Or just speed up some boring parts. -
Well, that's pretty much what my 2nd option question alluded to. I don't offhand know of any Player software that places metadata within the file, in an accompanying database or anything like that, though it's certainly possible.
But that's EXACTLY what a good NLE will have that feature for. While you're watching the clip, you hit a hotkey, it places a marker on the timeline of the clip (some you can name, others might just give numbers). Then you can go back and finely adjust the marker. Later if you actually want to edit using the markers as reference, you use combinations of GoTo+Marker#+MarkIn and GoTo+Marker#+MarkOut and create subclips, then you just work with those subclips.
Freeware, forget it.
Scott -
ShowSMPTE(), a pad of paper and a pencil.
Unable to load AVI files into Pinnacle 15 for editing purposes
By avz10 in forum EditingReplies: 28Last Post: 13th Feb 2014, 12:41 -
Portable HD for Archive Purposes
By bob52 in forum ComputerReplies: 9Last Post: 11th Mar 2013, 07:28 -
Premiere - Inserting Stopwatch Timer ?
By wet bimbette in forum EditingReplies: 4Last Post: 6th Aug 2011, 18:27 -
Downloading YouTube Clips For Editing Purposes
By foochuck in forum Video Streaming DownloadingReplies: 4Last Post: 1st Jun 2010, 03:11 -
Videos for Security Purposes
By guns1inger in forum Newbie / General discussionsReplies: 0Last Post: 10th May 2009, 20:47
