Hi all:
Trying to shrink an mkv video file with handbreak and after reading this guide:
https://forum.videohelp.com/threads/304167-How-to-make-a-single-MKV-from-a-Blu-ray-%28a...o-shrink-it%29
I only have the following doubt.
The guide says that on "video" we can select how many MB we want the final movie using the " TARGET SIZE"
However my HB vers. 0.9.8 , I see only 4 possibilities:
VIDEO QUALITY
video codec constant quality
frame rate avg bitrate (kpbs)
I don't have the TARGET SIZE option !!!
What to do if I want a final video with around 4.7 GB to fit a normal DVD ??
Results 1 to 11 of 11
Or use an older handbrake version, https://www.videohelp.com/tools/HandBrake/old-versions#download
If you are looking for faster converter then try kirara encoder. But might not be as simple as handbrake.
4.37 GB 'MAX' size in 'real numbers' for a DVD-5.
4.7 GB is sometimes stated, but incorrect. https://www.videohelp.com/dvd
4.2 GB is a good number for most dvdr blanks as you really don't want to write to the last couple hundred mb on the outer edge. the rest is there, but questionable for use.
Mkv to mp4 with handbrake
By hilario in forum Video ConversionReplies: 11Last Post: 5th Feb 2012, 14:27 -
MKV to MP4 converter besides Handbrake
By bowmah in forum Newbie / General discussionsReplies: 10Last Post: 19th Dec 2011, 04:04 -
MKV conversions using Handbrake
By havash in forum Video ConversionReplies: 1Last Post: 6th Aug 2010, 01:36 -
HandBrake No Subtitle in MKV
By kinghlg in forum SubtitleReplies: 3Last Post: 16th Dec 2009, 21:07 -
Handbrake 0.94 MKV to M4V encoding
By Scarpad in forum Video ConversionReplies: 5Last Post: 7th Dec 2009, 21:44
