Are there any ways to make an unfocused shot become more infocused during post-production? If so, how do I do it, and what programs should I use?
Results 1 to 18 of 18
Your brain may know what it should look like focused but software can't tell.
Unsharp Mask is typically used, and it's keyframeable.
It all depends on how bad the out of focus is. If it's momentary, like a refocusing during a camera move, it's often left alone. You can use the tool "Defocus" on top though, and make a transition out of it.
But as far as to create focus from out of focus, NO.Last edited by budwzr; 21st Mar 2013 at 10:47.
You might show us a sample of what you mean by out of focus. If you're talking about a bad fuzzy blur such that objects can't be recognized, there's little or nothing one can do.
The OP should note that it read: "Prototype", and "only works on certain kinds of shots with only 1 kind of blur in them" (not most general photos' problems), and "can sometimes misread elements and make the image worse".
Scott -
Similar limited scenarios, limited effectiveness, limited utility, LONG processing times. I remain unconvinced.
Scott -
It's an example of the sophistication and capability of today's algorithms. Not unlike the type of algorithm that sharpens images.
The topic is whether or not software can sharpen blurry images.
I think it's technically possible, but I don't know how you can take the human out of the cockpit.
Actually, Heggunte, I was throwing cover for Scott. Does that disappoint you?Last edited by budwzr; 21st Mar 2013 at 21:13.
Sure, compex AI algorithims can do fascinating things, but it is still utterly premature to think that these can or would simply undo longstanding, systemic problems/difficulties. These are useful for isolated, specific elements of problems, and like all NR/adjustment/filtering software methods, they come at a cost (which is likely at first hidden from general users). This sets up unrealistic expectations. To rely on this as aa panacea is to set oneself up for disappointment.
That's what I'm unconvinced about: that those suggested apps would even come close to fulfilling/satisfying the intended true need of the OP.
ScottLast edited by Cornucopia; 22nd Mar 2013 at 06:17.
MPC grabbing focus - don't want
By Monarch1st in forum Software PlayingReplies: 3Last Post: 17th Feb 2012, 12:07 -
Cannot Focus or Motion Blurrrr??
By Compo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 18th Aug 2011, 16:53 -
Focus question
By zsuppguy in forum Newbie / General discussionsReplies: 9Last Post: 12th Jan 2010, 16:40 -
Test Table out of focus on Timeline
By aboveice in forum Newbie / General discussionsReplies: 3Last Post: 2nd Apr 2009, 02:15 -
Upgrade Focus FS-4 to HD
By tennant in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 24th Feb 2009, 15:49
