i didn't see any reference from op to what limit to measure against..i.e., 480i/p to 1280i/p to 1080i/p for instance.
i spend most of the weeking searching for the original test pattern used in the dvd recorder tbc performance and could not find it, so i ended up re-creating one from scratch. took me some time to first find the orginal high res version, though not that i was looking for it, but that i recall seeing in recently. anyway, i found it and was trying to scale back down to the same one used in the discussions, but it was a pain and i gave up and saled my own version. it was a pain. i would still prefer the original but those links are long dead.
the point is, if you're not referencing by "standards" then it doesn't matter as much if just for personal use.
Results 31 to 34 of 34
I re-uploaded my old comparison screenshots here:
http://www.avsforum.com/t/1287869/ps3-vs-htpc-dvd-upscaling-comparison-pix#post_23331702
The PS3 seems to use edge-directed interpolation + edge enhancement + something else. To me the result is sort of a cartoony look where some details look expanded beyond their original bounds, if that makes any sense. -
Okay, so I have a VCD I want to display on a 1080p HDTV.
Video Enhancer is not kind to compression artifacts! I also tried with their YV12 deblocking turned on, and noticed actual details being blurred. It is certainly sharper than NNEDI3+Spline36, but with Sharpen(1) added I'm not seeing any frame where Video Enhancer doesn't look worse.
I can see the value of their comparison to grab metrics, but for the product they are selling they need to encode that downscale and show those results too. None of us are working from HD-mastered uncompressed SD sources we want to upscale. -
How to upscale with Nnedi3?
By VideoFanatic in forum RestorationReplies: 24Last Post: 21st Feb 2013, 14:16 -
Denoise before Upscale or After?
By VideoFanatic in forum RestorationReplies: 4Last Post: 28th Nov 2012, 04:54 -
Few questions: Upscale SD to HD?
By nic3 in forum Video ConversionReplies: 5Last Post: 9th Jan 2011, 09:32 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32 -
hdmi upscale through pc
By zinc in forum Software PlayingReplies: 3Last Post: 30th Aug 2008, 11:57
