I have gotten a .ts (transport stream) that someone recorded from an HD broadcast. It is 1920x1080, so I want to burn it to blu-ray. I know I can run it through TsMuxer and it will be in proper format, but I've done that with a .ts file in the past and it wouldn't play. So I'm wondering if there are any specific specs I should look for that will tell me if this file is bluray compliant, or if it will need a re-encode. I don't want to waste a blank BD-R if I don't have to.
Here is all Mediainfo says about the file. Thanks for any advice.
Format : MPEG-TS
File size : 20.2 GiB
Duration : 2h 36mn
Overall bit rate : 18.4 Mbps
Video
Menu ID : 1 (0x1)
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=15
Codec ID : 2
Duration : 2h 36mn
Bit rate mode : Variable
Bit rate : 17.1 Mbps
Maximum bit rate : 80.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.276
Stream size : 18.8 GiB (93%)
Audio
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : 129
Duration : 2h 36mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 431 MiB (2%)
Language : English
				Results 1 to 12 of 12
	It's not compliant - blu-ray max rate is 40Mb/s
 (Chances are your video doesn't really use that max rate, it's just a "label" , nevertheless it will cause problems with authoring software and many blu-ray players)
	For 3DBD, it's max 48Mb/s, but no matter. Other than that max, it looks to be OK on the face of it. However, there are other elements of the spec that wouldn't be evident in a simple MediaInfo output. MediaInfo doesn't do compliance checks, it only reads what is listed in the file. If you put this into a legit BD authoring app, it should immediately tell you whether it is compliant or not (because they do need to have compliance checks for everything to work correctly).
 You could always get a few BD-RE discs (aka RW). Then you wouldn't have to worry about ruining a blank BD-R.
 ScottLast edited by Cornucopia; 27th Mar 2013 at 19:10.
	Of the file he wanted to burn and did burn successfully, not the one that failed.
	... which is what I said. Again, I want the one that failed.
  Encoding SD video with H.264 to be 100% Blu-ray compliant.By PuzZLeR in forum User guidesReplies: 14Last Post: 19th Oct 2015, 18:12
  Blu ray compliant video from cameraBy Bassquake in forum Authoring (Blu-ray)Replies: 16Last Post: 22nd Apr 2013, 16:55
  x264 GUI specifically for blu-ray compliant elementary streamsBy turk690 in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Apr 2012, 20:20
  Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray playerBy brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 05:15
  Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM DriBy donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
