Results 1 to 10 of 10
  1. I am having problems with .d2v in tmpgenc and have already downloaded the patch and installed it. I am using Sefy's newbie conversion guide and used dvd2avi and now am on the tmpgenc part but it still will not recognize the .d2v file. Please help....
  2. make sure VFAPI plug-in is checked in the help dropdown menu in dvd2avi
  3. what do you mean checked....because when i click on the VFAPI plugin nothing happens?
  4. does it allow you to check the VFAPI plug-in? do u see a check appear to the left of it?
    if you can't check it...it means u don't have it installed....it's been awhile since i've had to deal with that..so i'm sure someone else here will give u details to fix it
  5. toymachines, get: TMPGEnc / TMGPEnc VFP Plugin / DVD2AVI complete zip!
    Then unzip ALL 3 of them into the same location! (SAME!), then run the TMPGEncVFP batch file, and this will register the DLL's into the system, and then try to open up your D2V files.
    PS: if the above process doesn't work, DELETE your entire TMPGEnc folder, and try again!
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  6. in reply to the post above this where can i get this complete package cause i am having the same problem as the topic starter.
    thanx Madhatta
  7. Originally Posted by Madhatta
    thanx Madhatta
    if you have ICQ, u can look in the profiles and add me to your list and i can send it over to u...however, it's pretty old version (but works fine for me)
  8. Check the links in the Classical Guide, you will find the complete package of DVD2AVI which includes the VFP, you can also check out Doom9, it has a new version with new options (already covered in the upcoming v2.0 of the full guide).
    Best Regards,
    Sefy Levy,
    Apr 2002
    England
    I had exactly the same problem. All i did was downloaded the newest vrsion of TMPGenc from the offical site. Once i did this, the .d2v file was recognised first time.
    Why say hello when you can say goodbye?
  10. hrm...doesn't the newest version of audio sync problems thou...or has it been fixed?
