hello everybody... i need your help please
I'm working with a small local tv station and want to feed in our video files in the cable network.
I actually have a working solution, but I'm not really lucky with it, because some cable reveiver (set-top boxes) have problems
when playing my stream. audio video dropouts.
Currently I'm doing the following:
- I have mpeg input files, 720x576, 16:9, 25fps
progressive, interlaced (bff, tff)
I convert them with ffmpeg to mpegts
output is almost similar to other tv stationsCode:ffmpeg -y -i $i -flags +ilme -pix_fmt yuv420p -r 25 -s 720x576 -profile:v 4 -bf 2 -b:v 4000k -maxrate:v 5000k -acodec mp2 -ac 2 -ab 128k -ar 48000 -f mpegts $FILE_TMP
for playout i use vlcCode:Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings, BVOP : Yes Format settings, Matrix : Default Format settings, GOP : M=3, N=12 Codec ID : 2 Duration : 27s 879ms Bit rate mode : Variable Bit rate : 3 101 Kbps Maximum bit rate : 5 000 Kbps Width : 720 pixels Height : 576 pixels Display aspect ratio : 16:9 Frame rate : 25.000 fps Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First
bitrate is really low, but setting it to 5 or 6mbit, set-top boxes have problems to display the video. Also I have to set audio bitrateCode:cvlc -d --loop --miface eth1 ../playout/$PLAYOUTFILE --sout '#std{access=udp,mux=ts,dst=230.1.0.2:5000}'
to 128kbit, a higher value results in dropouts.
I'm a bit confused about that, because other tv stations play with 4-12mbit and 192kbit audio and have no problems.
what I'm doing wrong?
I would appreciate every hints about my issue... maybe other solutions...
thanks for reading![]()
Just a wild guess, but maybe you need to add other parameters to the ffmpeg muxer.
For example:
Regarding the "playout", perhaps you'll also have to ensure the adequate packet size (188 bytes)-mpegts_original_network_id 0x1122
-mpegts_transport_stream_id 0x3344
-mpegts_service_id 0x5566
-mpegts_pmt_start_pid 0x1500
-mpegts_start_pid 0x150
-metadata service_provider="xxxxxxx"
-metadata service_name="xxxxxxxxxx"
plus a buffer size "big enough".
thanks for your reply.
my cable network operator told me, the settings are not necessary, because the are rewritten on their system.
where to add the buffer size and packet size?
added -bufsize 1835008 to my ffmpeg line and give it a try.
In vlc i found "mtu" and "ts-csa-pkt" (default 188), is it that what you mean?
mtu is 1500 i guess, but i do not know how to use these values -
Well, I simply repeated what is written in the ffmpeg documentation
, and since I don't use VLC, I cannot give an answer to your last question.
BTW,
http://www.waveguide.se/?article=creating-dvb-t-compatible-mpeg2-streams-using-ffmpeg
HTH. -
yes maybe bufsize does the trick... I already used it in my about 150 test streams, but didn't recognize any differences with or without this option.
perhaps some set-top-boxes need it.. will watch this the next days.
thanks so far -
You're welcome
Or should I say "not at all"?
Seriously though, now I think you should read more carefully the page I indicated in my previous post. Some/many
hardware decoders "don't like" open GOPs for example, and ffmpeg really doesn't enforce closed GOPs unless you set B-frames to zero OR disable the scene detection algorithm
Another thing, probably it's a good idea to increase the GOP-size to 25, 30 or 36 frames, so that you'll get a lower average bitrate without a significant loss of quality
Last but not least, perhaps ffmbc can give better results than ffmpeg.
Again, hope this helps.
I already found this article some days ago and played around with gops and buffer...
-bf 0 ?and ffmpeg really doesn't enforce closed GOPs unless you set B-frames to zero
changing GOP size will change this values i think!?
M=3, N=12
suddenly the M is missing after conversion
to be honest, i hardly unterstand the GOP thing...
@ffmbc
i'll look into it, thx
Transformation of the transport stream video to MP4 or MKV(without ffmpeg)
By Stears555 in forum Video ConversionReplies: 9Last Post: 1st Apr 2013, 05:51 -
Avanti -FFmpeg Conversion to Transport stream
By manding74 in forum Video ConversionReplies: 20Last Post: 6th Jul 2011, 08:44 -
HD mpeg2 transport stream re-quantization?
By live4ever in forum DVB / IPTVReplies: 2Last Post: 21st Jul 2009, 19:25 -
MPEG2 transport stream software
By PCNG in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2009, 14:10 -
Re-encoding MPEG2 Transport Stream (.ts) file
By kary.sharma in forum Video ConversionReplies: 2Last Post: 12th Dec 2008, 04:01
