Results 1 to 11 of 11
  1. Hallo everyone,
    I'm using SubWorkshop 2.51 but I would like to change and I'm asking you advice for another software.
    I am interested in two features:
    1 - The counter for words - which is not possible as far as I know in SW 4 -
    2 - Different colour just for some lines, which is not possible with srt files at all, as some of you explained to me.
    What would you suggest?
    thank you in advance.
  2. Banned
    Freedonia
    If you want color, you CANNOT use SRT.
    If you use SRT, then you CANNOT have color.
    If you want color, then use a format that supports it like ASS (Sub Station Alpha).
  3. Originally Posted by jman98 View Post
    ..that's why I wrote "Different colour just for some lines, which is not possible with srt files at all".
    I am just trying to avoid to spend time in looking uselessly for features I need in software I never used before by asking to some of you which knew already which can be good for me for these two things I need.
    Thank you anyway for your kind answer.
  4. Not being quite sure what you want but you could try SubtitleEdit.
    It'll show you char/sec, no of chars in the individual lines of a subtitle as well as total no of chars.
    You change color with a right click on a subtitle (or group of)
    And I believe srt supports color with a syntax like
    3
    00:00:16,030 --> 00:00:21,030
    <font color="#ffff00">Then use for example
    SubTitleEdit to create subtitles.</font>
  5. Originally Posted by videobruger View Post
    3
    unfortunately with srt files you loose every change when you save the file.
    That you suggest sounds good...
    Jul 2011
    Denmark
    Hi mari815!
    As jman98 pointed out Sub Station Alpha is a nice editor (but only for SSA files I think... and a bit old).
    Aegisub is, in my opinion, a better tool for advanced effects. Works with ASS files.
    Wheather or not the SubRip format supports color really depends on where/what you want to play your video.
    Most players on the pc support colors and so do many converters: http://ale5000.altervista.org/subtitles.htm
    Subtitle Edit has color support for SubRip files (right click in list view -> color), but only use the feature if your player supports it.
    EDIT: LOL, I must be a slow typer... two posts since I started typing
  7. Originally Posted by Nikse View Post
    Hi mari815!
    Most players on the pc support colors and so does many converters: http://ale5000.altervista.org/subtitles.htm
    Thank you Nikse. Do you also know if Aegisub has characters counter as well?
    Jul 2011
    Denmark
    Not as far as I know...
    What do you mean? Also in latest SE 3.3.3?
  9. Originally Posted by Nikse View Post
    Sorry Nikse, what is SE 3.3.3 ?
    I mean that with SubWorkshop i go in settings, I change the color of the line I want, Saving, Opening again the file... and no change is saved.
    Then someone here told me that Srt files doesn't support colors at all.
    By the way it seems I need to choose... colors or character count.
    Except perhaps for SubEdit, if i well understood the post from videoburger it should be possible with it doing both things..
    grrr...i need time to try and I dont have time!
    But when I'll find out I'll post it, you are all a big help for me!
    Jul 2011
    Denmark
    I'm the coder of Subtitle Edit (SE) so I'm not completely partial... but I don't mind mentioning other editors. Another one is VisualSubSync which do have characters/sec.
  11. Originally Posted by Nikse View Post
    So you'll be glad to have then an impartial opinion after i tried
    Hope soon...!
