MP4 format.
I record videos off my Directv DVR. I run things at 5000kbps with constant bitrate. 60fps. After I complete video, I run video through MediaInfo. Sometimes, the information shows up correctly (which means Ive had a successful capture). Other times, it does not. For example, the MediaInfo will show 386 kbps and 4.321 fps. When it does this, I am unable to edit the file without losing some of the file.
I have tried every software I can possibly think of. When I use MKVMergeGUI, the 3 hour file (for example) turns into a 42 hour file. When the 42 hour file is opened in VideoRedo, it is corrupt.
When I use VideoRedo with the 3 hour file, the resulting file is usually less than the Output Duration size. Meaning Ive lost about a minute or two from a broadcast.
Is there anything I can do to fix these MP4 files, or a better recording software that will not result in so many failures.
Please, I will pay someone via Paypal if you help me fix this. Ive had this problem for 3 months, and Im so totally at my wit's end, Im ready to throw in the towel and quit.
Cannot open .mov files in Total Media Extreme
By edong in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Jan 2012, 23:18 -
Does arcsoft total extreme have a 3 hr maximum limit for authoring?solved??
By yoda313 in forum Authoring (Blu-ray)Replies: 0Last Post: 11th Mar 2011, 13:41 -
Total Media Extreme makes coasters when creating DVD-AVCHD
By edong in forum Authoring (Blu-ray)Replies: 2Last Post: 29th Mar 2010, 14:53 -
Total Media Extreme Audio De-Sync Problem
By www1221 in forum Capturing and VCRReplies: 0Last Post: 27th Feb 2010, 19:35 -
just can't cut it with total media extreme
By romanticwarrior in forum Authoring (Blu-ray)Replies: 0Last Post: 31st Mar 2009, 04:24
