the quality of the sample I'm about to post is amazing! I don't understand how anyone could encode a file like this.
Results 1 to 10 of 10
Is an average 917 kbps especially low for 640x480 anime AVC video? It also seems to have been filtered, and that would have aided the compressibility.
I don't see anything special. Animated material usually compresses much better than live footage. Especially if it hasn't gone through a noisy analog tape stage. The low noise, low detail, simple motions, and numerous duplicate frames makes it very easy to compress.
I didn't know this; I always figured that any H.264 encode under 260mb would be bad compressibility wise. Learn something new everyday!
Considering that xvid would require bit-rates of about 800-1300 kbps for that resolution its not that unexpected.
Although Jagabo is correct about most animated movies, some movies like Barnyard, Cars and similar movies look like crap if you encode them at lower resolutions and lower bitrates. The kinds of movies that forced us to buy quad core PCs and good graphics cards
Please send your just complaints to Dark Shikari <-- clicky.
just for the fun of it, here's an example of some base settings I like for low bitrate for normal encodes:
(depending on the target resolution, frame rate and bit rate the level can be lowered)Code:x264 --pass 1 --bitrate XXX --profile high --level 5.1 --keyint infinite --bframes 16 --open-gop --b-bias 20 --direct auto --b-adapt 2 --no-mbtree --rc-lookahead 60 --ipratio 1.5 --pbratio 2 --qpstep 8 --aq-mode 2 --aq-strength 0.5 --nr 1000 x264 --preset placebo --pass 2 --bitrate XXX --profile high --level 5.1 --keyint infinite --open-gop --b-bias 20 --no-mbtree --ipratio 1.5 --pbratio 2 --qpstep 8 --me umh --subme 9 --trellis 0 --psy-rd 1:0.0 --aq-mode 2 --aq-strength 0.5 --vbv-maxrate 300000 --vbv-bufsize 300000 --nr 1000 --non-deterministic
Cu Selur
Ps.: Sorry, just realized how old this thread ist,..
High Quality At Low Bitrate?
By sanosuke in forum Video ConversionReplies: 4Last Post: 4th Apr 2010, 09:21 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 03:18 -
How to reduce blocky artifacts in low res, low bitrate video
By The111 in forum Newbie / General discussionsReplies: 48Last Post: 20th Mar 2009, 19:29 -
converting down to low size yet maintain good quality
By lawlbear in forum Video ConversionReplies: 3Last Post: 19th Dec 2008, 19:06 -
Low bitrate source to High bitrate target
By sameerdhiman in forum Newbie / General discussionsReplies: 2Last Post: 8th Nov 2008, 00:54
