Hi There,
I'm soooo confused & I hope someone can help me. Here's what I've got: MacOSX10.8.2, a stack of blank dvdr & software called BURN.
Here's what I CAN do: Convert a video to mpg using BURN, and burn it onto a dvdr BUT the disc won't play on my basic dvd player. It will play on my computer though.
What can I do to create a disc that will play on my stand alone dvd player?
Any help will be greatly appreciated!![]()
Results 1 to 10 of 10
Burn isn't capable of producing DVD video format output. You are simply burning data discs and your DVD player can't play such discs. I know this because I have a Mac and I have Burn, but it's a "surf the internet and send email only" kind of computer. I do all my video work under Windows.
Your choices are few with Macs. Someone here with Mac experience will have to help you. However, thank you for posting this in the Mac forum as we do have members who specifically look for those posts, so you should be able to get help soon. -
thompson615, , in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
How do you figure that? The website and user reviews claim otherwise. Data, Audio (CD-DA, MP3) and Video discs (VCD, SVCD, DVD, DivX).
I mean Burn is not a CONVERSION tool.
The OP seems to need a conversion tool like Nero where he can drop some kind of video input into it and get DVD video output from it. That's not what Burn does.
If you feed Burn valid DVD input, like a VIDEO_TS directory and the right files underneath that are valid for DVD, yes, it can burn that correctly. -
The .mpg files may need to be authored, which will create all the files and folders required to make a DVD that a DVD player can play, and the DVD files and folders need to be burned as a DVD-Video disc.
Burn has the ability to burn a DVD-Video disc. The credits for Burn list dvdauthor as one of its components, so it would be surprising if it didn't also include the ability to author DVDs. However, if Burn can't author DVDs the way you want and you need a different free tool, DVDStyler is a cross-platform (Windows, OSX, and Linux) DVD conversion and authoring program. -
Started BURN.
I left the BURN preferences in their default settings.
Selected the VIDEO tab. Then selected the "DVD-Video" option.
I dropped a MOV file into BURN. It converted it to MPG, updated it in the BURN window and saved it to my harddrive.
I added a couple of extra copies and clicked on "Burn". Burn burn't the disc.
I tested it in Apples DVD Player and VLC.
VLC played the content but not the menus.
Apple DVD Player displayed the menu(s) and played the mpg files OK.
Popped the DVD in my Bluray Player, it displayed the menus and played all the content OK.
I used a DVD+RW disc for this test. I like to test burns on a rewriteable DVD first. Saves money.
Hope that helps.
Why Won't it Play on my DVD Player?
By mreccentric in forum DVD & Blu-ray PlayersReplies: 17Last Post: 16th Jul 2013, 10:59 -
dvd won't play on player but will on computer
By bubbadss in forum Authoring (DVD)Replies: 9Last Post: 28th Apr 2010, 03:49 -
Combined 2 discs into one, but disc won't play on dvd-player...
By StrobeLightEpileptic in forum Authoring (DVD)Replies: 5Last Post: 7th May 2009, 22:24 -
Burned dvd won't play in standalone player
By Shotobits in forum Authoring (DVD)Replies: 12Last Post: 13th May 2008, 02:21 -
DVD player won't play movie
By justmehere in forum Video ConversionReplies: 5Last Post: 21st Apr 2008, 15:02
